Driver's door hinge issue
Old Jan 11, 2025 | 10:41 PM
asb32952's Avatar
It was squeaking so I put some garage door lube in there on both hinges. Don't know if it's a coincidence, but now, the kinks or the stops don't work. It seems to be totally free. Anyway is that part of the hinge repairable or do I need to replace just one or both? Is the driver side rear door from a same generation TL the same hinge from a boneyard? Thanks in advance.
Old Jan 12, 2025 | 07:35 AM
Assuming you are talking about a CL; therefore, which components below are you specifically talking about???
Old Jan 30, 2025 | 12:17 AM
asb32952's Avatar
Probably some kind of flange thing in the upper hinge assembly if that's separate.
Old Feb 3, 2025 | 05:44 AM
skyaa1's Avatar
2003 CL Type-S
For anyone hunting a door squeak, our CL had one that was always at the same door position - when it was almost closed or just opening. Turned out to be this black rubber flap for lack of a better word at the top front. If it gets dried out, it squeaks as it rubs, which is at the door position I described. I used some weatherstripping cleaner/treatment and it stopped. I have to periodically do it again but try that if nothing else works.
9nerkitty
Apr 30, 2019 05:47 AM
solefly
Oct 30, 2012 11:31 AM
kel909
May 3, 2009 09:33 PM
yongque
Jan 29, 2007 08:43 AM
jfprl
Jul 27, 2006 07:41 AM
