Driver Side Windows wont go down all the way!!!!!
the hell is this......
when i press down on the auto window button to open my driver side window, the window does down about a 1/3 way down and then stops. then when i press it again, it goes down another 1/3. so basically, in order to open my window all the way, i need to either press the damn button 3 times or hold it down!!
is anyone else having this problem?
i bought it to the dealer yesterday, and the mechanic said its probably some sap that got in between the door and the window. so he cleaned it out and reset the "timer" or "computer memory" of the window <~~ wasnt quite sure what he was talking about. but then, after work, i tried opening my window, and the problem still exists!!!
can anyone help me out with this problem, so maybe this time when i go back to the dealer, i can tell him exactly what's going on and how he may go about fixing it, instead of him telling me some sap got in my door!!!
thanks guys.....
thanks guys.....
You might be having the same problem I had with my '94 Prelude. I spoke with the service manager, & he said to spray silicone spray in the the window channel (rubber(?) guides on both sides of the glass that keep the glass in the proper plane). He said that's all the dealer does when people bring it in for that problem. I tried it and it solved my window problem. Hope it does the same for you.
Originally posted by NOVAwhiteTypeS
happens to me when its hot out side.
dealer blammed it on tint. but seen it happen to non tinted typeS's too. oh well
kinda sucks to pay like 30g to have a problem like this cause its summer........freakin my old ass camery didnt even have this problem.......
<~~CL-S getting on my nerve~~>
btw.....did anyone else hear about the recall for 2001 CL-S for engine oil leaks.....???
<~~CL-S getting on my nerve~~>btw.....did anyone else hear about the recall for 2001 CL-S for engine oil leaks.....???
Let me put it to you this way....minor problems are made all the better when you hear the dual plenum intake and then the VTEC kick in....
here was the recall i was talking about.....
http://www.alldata.com/TSB/01/01012332.html
Bulletins for 2001 Acura CL TYPE S V6-3210cc 3.2L SOHC (VTEC) PGM-FI
Service Bulletins
TSB Number Issue Date TSB Title 96-025 DEC 01 Navigation System - Component Exchange Program
01-017 OCT 01 Brake Pedal - Pulsation
01-041 OCT 01 Engine - Oil Leaks
99-051 AUG 01 Exhaust - Muffler Paint Peeling
00-037 AUG 01 Brake Disc - Refinishing Guidelines
01-004 JUL 01 Wipers - Smear or Streak the Windshield
00-009 DEC 00 New Models - Feature Information
00-032 NOV 00 Moonroof - Squeaks from Moonroof Seal
00-033 NOV 00 SRS - MIL ON DTC 15-1 Set
00-019 JUL 00 Immobilizer System Type 2 - Information
99-041 FEB 00 TQI OF THE DVD NAVIGATION SYSTEM
Service Bulletins
Been 105 index here. I used to have the problem. Dealership fixed it last year! I dunno what they did, but it doesn't happen anymore. I do remember the tech saying something about a window relay. And something else...
I'll ask next time I'm in there, and post again with the fix they did.
Happened to my son's '97 - thought it was a relay. The mechanic said relay was fine, just greased the regulator and scissor bars that raise & lower the window. Had to take door panel off. $105 Labor $2 parts.
I've had the switch replaced twice and the motor once, still fails. It is not just hot, but rather sun shining on the drivers side door. Mine will fail with temps in the mid 80's as long as the sun has been on the drivers side door for a couple of hours..
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
