Driveline Vibration?
Problem:
When accelerating from 38-45 i get a hard vibration from front of vehicle. Car is lowered with coilovers. I have brand new rims, tires, and entire front end suspension (ball joints, control arms, tie rods, bearings). I replaced parts cause a few were worn out and figured best to do it all since I can do it so cheap. As soon as I let off the gas it goes away. As soon as I get past 45ish it goes away. At highway speeds I never feel it. Its only at that speed so i have ruled out rpm vibration (motor or trans mounts etc) unless I'm just totally wrong....
I have done some research and I've found that a common problem when lowering the car so much is you can get some driveline vibration. Basically the driveshafts (half shafts) are extended past where they normally would be so the joints/cups in the axle/driveshaft/half shaft are just worn out. I have never replaced the axles.
Should I just replaced the Axles? Upgrade? Input on this? I'm going crazy with this vibration.
Regional Coordinator (Texas)
its ur axles. guaranteed. just replace them.
this kind of problem only occurs when u hit a pot hole or something.
I had the exact same problem, early 09, replaced the axles with some regular autozone/orielly axles and its still good.
Keep in mind, if ur gonna try diagnosing it, you will waste time because there is no way that you can tell by looking at the axles if they're bent or broken, in this case.
Whats up with RDX owners?
Usually it is the axles. Mounts could be the culprit as well.
Trolling Canuckistan
Not necessarily.
Yea, I just re-read the post. I thought he meant 3800-4500rpms, not mph.
So most likely axles.
I just started experiencing a similar problem, drive-line/wheel shake feeling putting any power to it when going up hill or any situation when the suspension is loaded more than normally.
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
