Don't buy cheap non-OEM rubber refills for your wippers
Listen to this, my OEM wippers got worn out, so I went to Pep Boys and got some Refills (Anco ??). 3 month latter, I notice wierd noise when my wippers are on, I take a look and:
One plastic on the refill blade is broken, and mettal part that hold the rubber in place is scratching the windshield. Now I got a scratch on my windshield
ANYBODY know if its possible to use some solution to remove small scratch on the windshield? Its very small(very thin), but you can notice it. Can I get some kind of acid or something to remove it?
Thanks for your help, and never buy non-OEM refills for your stock wipers!
I miss my 03 CL-S :(
I wouldn't say "never buy non-OEM regills"... just don't buy cheap stuff...
I've been super happy with Bosh MicroEdge Excel for quite some time. Zero noise and no scratches anywhere.
Now I got a scratch on my windshield, is there any way to remove it or make it little less obvious?
Originally posted by russianDude
Its not about being cheap, you either buy comple wiper blade, or only OEM refils. The thing is, that some refills are not a perfect fit, and can slip or break.....
If your nail doesn't "catch" on the scratch:
Glass Polishing Kit Pro
Item No. - 40011
This kit can be used to clear off years of wiper haze from your windshield and save hundreds of dollars in replacement costs. Ideal for hard-to-find windshields on older cars. Try this test: Run your fingernail over the damaged area on your windshield. If nail doesn't catch this kit will work. If your nail does catch try the Deep Scratch Kit (40030). Mark the damaged area mix the special Glass Polishing Compound with water, attach polishing buff to your drill or low speed polisher (1,500 rpm), and start polishing! Includes: 1/4 adapter, 1 lb Glass Polishing Compound, 2 7/8" x 1" Thick Buffing Wheel.
Regular Price: $34.99 This item is in stock.
DEEP scratch kit:
Glass Polishing Kit For Deep Scratches
Item No. - 40030
Remove Deep Scratches From Glass - Now you can recondition deeply scratched automotive glass and save the replacement costs. This abrasive system literally grinds away imperfections until scratches disappear. Works with your 4 1/2" or 5" air angle grinder set at 2000 rpm. WARNING: This System Removes Glass. Keep Glass Wet With Water and Spinning Abrasives Moving Across Entire Surface to Avoid Heat Build-Up and Optical Distortion. Includes: Self-adhering hook and loop pad, coarse, medium and fine abrasives, Pro Glass Polishing Kit (40011) and instructions.
Regular Price: $45.99 This item is in stock.
AND...
Finally, to try and "hide" the scratch, you can use this. It also protects the glass with a polycarbonate coating (I'm using this stuff under the Zaino now):
http://www.diamondite.com/shield.htm
If you have 'MINOR" scratches or very tiny pits (TINY), the stuff will help cover them up... It won’t fix meteor strikes...
YMMV
Originally posted by EricL
AND...
YMMV [/B]
AND...
YMMV [/B]
So it only hides scratches, how offten does it need to be reapplied?
thx ErricL
This one seems to be used for protection, does it really hide MINOR scrateches? My scratch is minor, and my nail does not get stuck in it... very fine thin...
thx ErricL
thx ErricL
Only hides.
I use it as layer #1 (got to remove ALL Zaino). (Can put Zaino on top after it cures...)
It better be small. It works well on those very, very small pits that are in the glass from bits of junk hitting the windscreen at 80+. My wife has some very minor scratches that "went away". IT won't help sandblasted and/or badly pitted/scratched glass and if the scratch is deep enough, you probably will need to grind it down.
BTW, It's really hard to judge what gets covered up and what doesn't.
YMMV
Every 6-months.
Only hides.
YMMV
Every 6-months.
Only hides.
YMMV
Did you get it online, do they sell that stuff in Pep Boys or autozone?
I looked at it more, it might not even be a scratch, looks like something very thin ( far smaller than a human hair ) just left a footprint... maybe some strong soven will remove it or make it less noticable.... I need to try some stong glass cleaner... hmn..
thanks for info anyway
Xe- For Better Hwy Vision
GET OEM BLADES FROM ACURA
It's the best $6.99 you'll ever spend. Don't waste time
with the shit they sell in Kmart and AZONE
I have used BOSCH in the past, few bucks more.
You can always go over to the Autopia forum. This issue has been discussed...
Be very, very careful of what kind of solvents you use near the paint.
Brian is one the owners over at Diamondite (really nice guy)!
Autopia link (car care): www.autopia.org
If it doesn't come out with the some good window cleaner, you can always repost over on the autopia forum (and/or do a search).
AS others have mentioned, get the OEMS or get some PIAAs (silicone) or Bosch (graphite) if you want to "play" with replacements...
cycdaniel
12-17-2019 10:58 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
