Does everyone check their Actuator from time to time ?
#81
MP90 uninstalled
yeah... emissions, right? It took everything in me not to go postal when this guy started talking. I didnt say a word. just thanks and drove off. however, I fully intend to take the old IMRC and the new one and give an acura tech a lesson on how to work on acuras. cant wait. I go to Baton Rouge on business often so it will be easy. As shitty as is it is, this is the closest dealer to me. Or i could drive two hours to go to New Orleans and I dont even know if the dealer there is open yet (hurricane Katrina). Acura wont put a dealership in Lafayette, LA because they think they cant move 400 units a year. WTF? mercedes, BMW, and just about everyone else does here. there are almost 200,000 in lafayette and it is expected to continue grow at a rediculous rate. OK, I am a little pissed, sorry if i got a little worked up there.
#82
MP90 uninstalled
can someone please find an electrical scematic for the IMRC from the pcm? what is the signal like that controls the IMRC. I have read something about ground logic for the digital system that controls it.
HELP PLEASE!
HELP PLEASE!
#84
MP90 uninstalled
no, i dont have the new part yet. it is in the mail. As a crazy physics guru, I want to understand why I cant get a definable reading from my meter off the IMRC plug.
#85
#86
MP90 uninstalled
I am beggining to think that is possible. I think I am getting something at about 4000rpm. the needle on the voltmeter set at a max of 10 volts or set at a max of 50 volts DC makes the needle move a thousanth of an inch about 3-5 times a second no matter which way I attach the wires to the IMRC plug after passing 4000rpm and continues to do so after the engine rpm falls back below 4000rpm to idle. any ideas
#87
i would think that we need an eletrical guru, im not an EE major, but i am in computer technology... are you testing it while reving to 4,000 rpms? silly question but still. also, try just grounding one end of ur meter to the chassis/frame. and test each pin individually, it's only a 2 pin plug.
i personally have never tested the IMRC plug, but my guess is you will see 1 of 2 things:
1) jump to 10-12v
2) constant 10-12v and then a drop in voltage.
the latter is unlikely, but you never know.
edit: sounds like your not using a digital meter, we're talking fractions here, it's possible it only will jump 4-6v which may seem insignificant on traditional meters. but try grounding to the chassis.
1) jump to 10-12v
#88
Greetings jproy,
1. Calm down now and don't blow a fuse over this minor problema.
2. Install your new part when it arrives.
3. Order new "how to do-it-yourself books" from Helm publications.
4. Use this toll free number ---- 1-800 782-4356. ONLY $134.00.
5. Enjoy your new found knowledge gained from new book.
Kindest Regards, sq.
#89
MP90 uninstalled
1) jump to 10-12v
1) jump to 10-12v
#91
MP90 uninstalled
Thanks for the FYI but I what to know how the signal is being electronically sent. I would like to se a schematic of the electronic system for the IMRC as well.
#94
MP90 uninstalled
CLSDefiant, You should read an entire thread before you post in it. YOU will get flamed for this. Anyway, If you had read the whole thread like everyone else, you would have seen the photos of the IMRC and how to check it and if so you would know by looking at your own that there are only two bolts holding it on the back of the rear head and a cable that you must disconnect. it takes ten minutes.
#96
NO, sorry guys, i apologize im always in a hurry, im working like 4 jobs and whatever chancce i get inbetween i post, and im 18....
BTW my actuator is working, but is it just me or when the car is in park it doesnt let you revv above like 5700 rpm cuz of that rev limiter or is it just cuz the actuator opens.
ONCE AGAIN I DO APOLOGIZE, i just wont bother posting next time...
#97
BTW my actuator is working, but is it just me or when the car is in park it doesnt let you revv above like 5700 rpm cuz of that rev limiter or is it just cuz the actuator opens. PS my actuator even though its a type S opens at like around 5500 or its just my imagination cuz i wasnt looking at the RPM guage when it opened or is it that its limited revvs to 5500?
#99
MP90 uninstalled
CLSDefiant, this is a thread about the IMRC or Actuator Bypass Valve. U R in a hurry? if you dont know what it is, do a search BEFORE YOU POST. there are a million threads about what it is and how to change it. it takes ten minutes to change. I dont care how old you are. if you dont have something to say that is relevant to this thread chill. these threads are referenced by other new people long after you and I talk to see what is happening to there car and you are crapping up this thread. the current topic is how the signal is sent to the IMRC. I will be happy to help you just pm me and I will tell you whatever you want to know if you need help. SEARCH, then ask quesitons, then post.
#100
but anyways, i was sitting in park or neutral and i was revving and my car got to id say 5500 and then it wouldnt go any higher but when im in drive it easily goes to 7 whats up with that? is that normal?
#101
Received 1,080 Likes
Yes it's normal. It's to prevent idiots from destroying their engines showing off in a parking lot.
#103
Next Car Coming Soon
[QUOTE=CLSDefiant]for your infor jproy, if u didnt see i posted something and maybe YOU didnt read it, i dont need 70 people telling one thing, i only need one. so incase you didnt notice and i dont mean to be rude, people got their point to me.... so you chill.QUOTE]
a person can only take soo much of shyt talking, this is defiant-->
![Hurl](https://acurazine.com/forums/images/smilies/hurl.gif)
#104
[QUOTE=609CLTYPES]
well yea, but anyways, i have seen that my actuator works and i just resetted the ECU by disconnecting the battery and the check engine light went away. :-D my acutator works!
a person can only take soo much of shyt talking, this is defiant-->![Hurl](https://acurazine.com/forums/images/smilies/hurl.gif)
#106
Whats up with RDX owners?
Theres a control box on the driver side near the fuse box IIRC. That controls the opening, but the ECU sends the signal to the box.
#108
Use an RPM activated switch. I forget the title of the thread but there was one on here regarding it.
#110
Yea. The RPM switch should be simple to wire in, and theres only two wires going to the IMRCs.
#111
I Drive Like A Dick 8≈
![](http://www.acuraoemparts.com/delray/jsp/catimgs/13s3m0_e0320.gif)
Just to make sure, the part that needs replacing is "1" in this picture right??
for future reference here is the part number for that
17151-pfw-j02
#112
I never checked this... I have about 103k now... I def should. For the past few months I still get this noise around 4100. A squeak kind of sound when the RPM's come down... I wonder if this is related to my problem. How much is this to replace? Is it simple enough to do yourself? or do you need to take it in to replace?
#113
Its easy to replace. Its bolted to the rear valve cover with two 10mm bolts, and the cable is bolted to the manifold with 1 10mm bolt.
I forget the exact RPM that it opens, but I dont think its in the 4k range. With the car parked, rev it up - somewhere in the 3k rpm range you should see the pulley on the side of the manifold flip open.
#114
Just checked it. It opens but around 4100 when the RPM's come down there is a sound that comes from that part. Is something broken internally? That is exactly where the sound is coming from. Should I replace it? Any idea of the cost?
#116
IIRC the motor is around $80 with discount. I wouldnt replace it though. If it aint broke, dont fix it
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#117
its just that NOISE that bothers me... every time at 4100 "kssk" so if its cheap it worth replacing so I don't have to listen to that DAMN NOISE NO MORE!!!!!! AAAAHHHHH!!!!!!!!!!! took me this long to figure out what was making the noise.
#118
Are you 100% its coming from that and not the rear head itself??
#119
Hello everybody, have been trying to see the pictures and open the video link posted previously on this thread but it has been impossible... have searched arround to try and find somewhere else but with no luck. Would really appreciate if someone can post image or link where I can see actuator (video better). Do I have to take apart any cover? air filter? to see actuator... (mine is a '01 CL-S 5AT)... thanks in advance.
#120
Remove the top plastic cover over the intake manifold. Look at the left of the manifold, you should see a cable. Follow that around to the rear of the motor. Thats the actuator.
