Do I have a problem???
Old Aug 11, 2002 | 05:52 PM
BlackShadow's Avatar
O.G.
Yesterday I was taking off my front 2 tires to switch them. As I was getting ready to tighten the lug nuts, the tire turned with me. Now if I'm not mistaken, the tire should be in a lock position, meaning it can't turn, right? I am not talking about left or right but turning as in when the wheel is in motion. The engine was off and the key was out of the ignition. Does it happen to you guys too or is there something wrong with mine? I know that my dad's 90 camry and my mom's 90 accord front wheels lock up.
I need to know.
Old Aug 11, 2002 | 05:57 PM
sidemarker's Avatar
same thing happen to me
dont know why. Since the car is in the park position the front wheels should not move at all???/
can someone explain
sidemarker
Old Aug 11, 2002 | 06:29 PM
BlueCLS6's Avatar
ex 6 Speed owner :(
Yes, it is the Differential. The transmission is not moving because it is in park but if you notice... the other wheel will be spinning in the opposite direction...
Old Aug 11, 2002 | 06:52 PM
O.G.
So is it safe to assume that it is normal then?
Old Aug 11, 2002 | 06:56 PM
haiduc's Avatar
Moderator Alumnus
yeah it's normal....
if you had a locking differential both of the front wheels would turn in the same direction.
uh... why are you trying to tighten the lugs when the car is in the air?
Old Aug 11, 2002 | 07:17 PM
O.G.
I usually try to tighten it a little first before I lower the car to the ground. I do this first because I don't want the whole weight of the car on a tire that is not tighten at all. Then I really tighten it once the tire is on the ground.
BTW, how do you think the dealer do it? The car is always up on a lift so it's the same thing I'm doing. Except they have an air gun and I don't.
Old Aug 11, 2002 | 07:25 PM
AkuraCLS's Avatar
ALi G in the House!
if you put on ur parking brake, i don't tink it'll turn...
Old Aug 11, 2002 | 07:41 PM
O.G.
I also did that but the tires still turned.
Old Aug 12, 2002 | 03:53 AM
AztecRol's Avatar
The Screeching Toyo's
Parking brake only works on the REAR tires.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
