DIY:road lamps into HID fogs
Old 11-24-2009, 09:10 PM
To many cars in my garage
MrFluffy's Avatar
I really wish someone would put this in the DIY section
There are 2 parts to this first is the modification to the housing 2nd is the wiring
Supplies
1, HID Kit $60
( HIDXTRA https://acurazine.com/forums/showthread.php?t=723872 )
2, 4 wire connectors $1
3, 2 small scres $1
4, duct tape $6
5, electrical tape $2
BTW Total $70.00
tools
1, drill
2, 2" bit
3, 5/32 bit
4, screw drivers
1st part
1,
take out the housing there is one screw holding it in this screw is acessable throught the lower grille, if you look at the fog light from the lower grille you will see it, then it just pops out ( used a flat head screw driver and a rag to pop it out.
2,
this is where people get a little squeemish but I asure you, you canot see it at all and it does not affect light out put
take a 2" drill bit and drill two large holes over the top of the fog light housing directly above where the bulb sits ( this is how I got around the heat problem)
The bulb install, I used H7s for the bulbs, I drilled a small hole in the lip of the hid bulb and into where the lip that is on the housing, then put a small screw , throught the bulb lip into the housing
2nd part
1, start with the harder side the passengers side , Cut the three wires going into the old bulb,one is red,one is red and one is black (thats right two red I thought this was weird then I relized that they wired the headlight and road lamp as one circuit "kind of")
any ways attach the two red wires toghether and attach those 2 red wires to the positive on the HID, then attach the black wire to the negative on HID.
the passenger side is the same except there in only one red wire.
2 plug it all in and your done
I attached my ballast to the bottom of the bumper with one srew , I also suggest wrapping it in a sh## load of Duct tape just to be safe especialy if it not water proof
Old 11-24-2009, 09:21 PM
MrFluffy's Avatar
Heres a pic of the finished product that ive had for 2 years 1st year I had 6000k and the second year and these are 8000k
Old 11-24-2009, 09:34 PM
3.7L Nitrous Breathing CL
richardparker's Avatar
I have tinted roadlamps. And every kind of bulb I have tried really dont get bright since the tint holds back the light.
Would the HID shine threw or would it be pointless to even bother with?
Old 11-24-2009, 10:07 PM
MrFluffy's Avatar
LMAO, I tried to do the lexan conversion so my road lamps didnt look cheap when they were off ened up destroying the fog light , any ways I ended up tinting it blue to hide it untill I found a used fog light It was stil brighter than a halogen bulb but a little to blue for me
So yeah it definitley shine threw
Old 11-25-2009, 12:18 AM
BT5150's Avatar
Thanks for posting that Mr. Fluffy! I'm planning on doing a HID foglight of some sort as my first mod project for my CL. One question I have is how the light comes out of the road light, I mean does it have a good pattern or is it all over the place? I'm wondering because the road lights just come with that 5w bulb, so I'm thinking that the reflector inside isn't really designed to throw a real bright light out of it. I just don't want to end up throwing light all over the place and have people flashing me cause they think I have my brights on.
My other thought is to buy a projector light kit like this one:
http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
They take H3 bulbs and they are all metal, they even say that they are HID kit ready. Assuming they'd fit in the space where the road lights are, I'd take out the road lights and fabricate a mounting piece to surround these lights to fit in the space where the road lights are now.
Old 11-25-2009, 12:35 AM
MrFluffy's Avatar
That is a really good price im thinking of doing projector hid high beams
I think I have siad this before but my thought on the light pattern is that, I believe by the way it is designed and the way I find it lights up the road, acura made it for a normal bulb and then when it came for the final cuts in the manufactoring budget it didnt make the cut. so the light pattern is good just like a normal fog light, it lights up the ground and too the sides.
I have never got high beemed in the 2 years Ive had them( except by my brother but thats because he hates my head lights and hes a Jack ass) because they are not focused up in people eyes and there great for counrty roads when you need to see animals on the side of the road
Old 11-25-2009, 05:24 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,353 Likes on 4,915 Posts
Dont waste your money on those. The output sucks.
Ill take some pics tonight (or at least try to) of my fogs. With any luck I should be installing them this weekend.
Old 11-25-2009, 08:59 PM
MrFluffy's Avatar
I found some 24 projector that are oem it says I was thinking of those
Old 11-25-2009, 11:01 PM
I got the Shifts
phee's Avatar
damn. i just bought some civic fogs for my car. shoulda got those projectors
Old 11-25-2009, 11:08 PM
MrFluffy's Avatar
I meant to say A4 or rather A6 heres the link needs some costom work but the light output is probably really good
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 11-26-2009, 01:14 AM
civicdrivr's Avatar
I tried taking some pics of the output tonight but the pictures sucked. Ill try again tomorrow.
Old 11-26-2009, 08:47 PM
MrFluffy's Avatar
Ive never been able to take pics of ligth out put and I have a pretty good camera so if you figure out how to do it please tell me
Old 11-26-2009, 11:30 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
wait.. u mean the ebay link there of those fogs. are the right size to put in the circular looking thing inside the light housing... as in u cut out the back and retrofit it?.
That'd be SEXY like fuck yes
Old 11-26-2009, 11:35 PM
MrFluffy's Avatar
Im not sure if it would fit, but it looks like it would, but it would require a lot of modding to the light.All i know is that it is a little smaller than 80mm(angel eyes)
This is my next modd im going to collect the parts over the winter and do it next spring
Old 11-26-2009, 11:49 PM
lol yea i'll be tackling the front lights also. foggs first. i'll have to do my hmw for modding the headlight housing to fit the DRLs. If I do it tho, I'd take apart the lights and do the angle eyes as well.
Old 11-26-2009, 11:52 PM
I really want to take off the manifold and paint it and the front valve cover also. but i'll have to wait for warmer days.
Old 11-27-2009, 12:03 AM
lol i just did my calculations for the $ i've spent on mods. excluding rims $2810
And i've SAVED $1720 through getting free stuff (for presents or working on my buddys car) but most of it ($1000) was due to finding deal on this forum.
I luvvvv AZINE
I want an azine stick to go over the 3rd brake light (since I have the spoiler) since that light is for show anyways. I want one that covers the whole thing and then cut out is Acurazine.com.
would be nice is silver
Old 11-27-2009, 12:58 AM
civicdrivr's Avatar
$2810?
Loser. Ive got almost $12k into this car
Old 11-29-2009, 03:57 PM
DFW AREA,
duyx817's Avatar
wont the hid bulbs lose life, because they are in fogs?
why i ask?
when you lock or unlock it makes the hids blink (fogs or roadlamps). i thought this is bad for the hid kit.. is this true?
i am a 03 acura cl-s with accord fogs that is relayed to the corner lights
any comments will help ty!
Old 11-29-2009, 07:52 PM
MrFluffy's Avatar
Dont Relay to corner ligths
Relay to hids, Stock or
Ignition switch
Old 11-29-2009, 08:05 PM
DFW AREA,
duyx817's Avatar
Ignition switch
do you remember whats the color wire to the hid's?
Old 11-29-2009, 08:15 PM
MrFluffy's Avatar
Mine Is probably going to be different because its an 01 type s but I do remeber its red and black
I would wire it to an ignition wire with a switch so when you turn the car on the lights go on unless the swich is off
The best way to do this is find a fuse that is on when the car is on(dash lights is good) and wire it to your switch and then your existing relay
Old 12-09-2009, 01:53 PM
MrFluffy's Avatar
HERE are some pics of what the road lamp looks like
Old 12-09-2009, 02:51 PM
civicdrivr's Avatar
Whats with the hole on top?
Old 12-09-2009, 03:26 PM
MrFluffy's Avatar
Read my DIY, Its for the heat to escape so it doesnt melt
Old 12-09-2009, 05:23 PM
Chamorro
dave586270's Avatar
Thats a big hole, lol. You realize that HID's put out less heat than Halogens. They wouldn't melt that housing if you left them on all day.
I'm curious though, how you mounted the bulbs to the housing? You said you used screws, but you can't see them in the picture. Either way you did a great job man!
Old 12-09-2009, 10:05 PM
MrFluffy's Avatar
The first time I did them they melted, than I drilled the hole and they worked fine
Old 12-10-2009, 06:18 PM
Chamorro
dave586270's Avatar
Really? Well then it looks like you did the right thing
So what did you use to attach the bulbs to the housing? Any problem with aiming? Hard to tell from the pic how they are held in place.
Old 12-10-2009, 07:32 PM
MrFluffy's Avatar
Sorry about that I will take another pic tommorow if I have some time, I forgot to move that rubber piece I did not aim them but they seem like they are fine the way they are but you would have to tilt the housing and its not worth it time and effort. like I siad they seem fine
Old 12-11-2009, 05:51 AM
Chamorro
dave586270's Avatar
No worries, just curious to see how you mounted them. i was looking to do this exact thing. I mean i like my LED's for now but i'd like to do a matching HID kit in the parking lights when I redo the headlights.
Old 12-11-2009, 08:30 AM
MrFluffy's Avatar
Do you mean the corner lights? I just did LED corner lights and I thought they were going to be the same color as stock HIDs ( 4300k) but then ended up being the same as my fogs (8000k) but they look way better than orange. the guy I ordered from sucked because they are suppose to be dual filiment and they were not. But Im doing a new mod for my front signal lights once my parts come in !! Im still not sure if I will post it thou
any ways here you go you have to be very carefull when pre drilling this that you dont hit the bulb , and find the smallest screw you can. you only need one, It works really well too because this is my second set of bulbs first was 6000k but I got in to a minor accident involving snow ripping off my bumper and one of my ballast flying over a bridge so I had to replace it and it was really easy
Oh and very important the bulbs are H3s not H7s if some one could edit my first post
Old 12-11-2009, 09:05 PM
I Drive Like A Dick 8≈
Nersh7's Avatar
Shit I was going to ask you about the 2" hole because I've never seen a bit that large and thought it may have been a typo but I guess not haha
Old 12-12-2009, 05:32 PM
MrFluffy's Avatar
No its 2" kinda of scary but it doesnt hurt any thing and there only like $35 any ways
Old 12-12-2009, 06:32 PM
Any moisture issues with the hole ?
Old 12-13-2009, 06:14 PM
Chamorro
dave586270's Avatar
Damn you screwed 'em in? Your brave. Well i've got a few months of winter here so maybe i'll pull mine out and start on a little winter projector for next season!
Old 12-13-2009, 10:53 PM
MrFluffy's Avatar
Just be carfull and use the smallest screw you can
and there are no moisture issues I think one reason is its not a sealed unit and there is a bumper over it so they seem fine and, we got a lot of rain this year !!! and even if it does get moisture in it I think the heat of tthe HID would evaporate it ?!
Old 12-14-2009, 12:52 AM
Nersh7's Avatar
ya that probably would be the situation, my only worry would be if any water got on the hot bulb and it goes !boom!
Old 12-14-2009, 02:38 PM
MrFluffy's Avatar
I dont think it would go boom but I got 1 extra bulb I may try it LOL
But like I said it been there for 2 years now and no issues
Old 12-14-2009, 04:08 PM
is there anything I can just plug in an have better/different color light from?
or do i have to modify this POS to be brighter like i want it :-(
Old 12-14-2009, 09:16 PM
nf3d0149ab's Avatar
Thanks for the DIY
Quick Reply: DIY:road lamps into HID fogs
