DIY Air Filter Replacement
It's Always Shabbat
All,
About two years ago I replaced my air filters (the ones behind the glove box) and I did so by following directions/diagrams I found on this site.
Anyone know where to find them? I don't see a DIY section or an archive like there was on the old site..
If anyone can help, I'd appreciate it. I did try using the search feature but to no avail.
Thanks.
Thanks.
Here is the excerpt from Jens on changing the "panel filter":
To access the interior air filters you will need a Phillips screwdriver, a pocket flat blade screwdriver and a sharp knife. Open the glove box and empty it of whatever you have been hiding in there.
There is an air piston on the right side that slows the opening speed it is attached to the door with a screw, remove the screw, and pop off the air piston.
There are two stops on the inside the glove box, pop both out with the small flat blade (screwdriver?).
The glove box will now open downwards, there are two Phillips screws holding the door to the dashboard structure. Remove both screws. The door can now be removed.
You will now see two Phillips screws that appear to hold nothing in place, remove these. Leave the metal clips in place.
There is a serrated panel visible -- it must be cut away from the dashboard structure. Save this panel as it is to be reused later.
There is now a vertical white plastic panel visible that can be snapped out of the way and removed.
The filters are the two vertical boxes that are now visible. Remove the bottom one first by pulling it towards you then lower the upper one and remove it as well.
Exchange the filters noting that they have arrows on them for airflow. The boxes that contain the filters are marked as well. Install the filters in the boxes and reassemble the filters into the air box. Take the white panel and snap it back in place.
Now take the previously cut out plastic panel and turn it so the two hooks engage the two slots in the dash structure. The two screws that did not do anything are now used to secure this panel in place.
Reassemble the glove box in reverse fashion from disassembly.
This job should take you about twenty minutes or less.
It's Always Shabbat
These are the air conditioning filters, btw.. IF anyone has a reference to the correct part number, that too would be appreciated :-)
They are technically called cabin filters, but these are the directions you need.
As for part numbers, don't know. They are like 15 each (there are 2) from the dealer.
haha... purolator part number is C15390... I'm full of stupid info like that. Don't know why I can remember it, but it helps in the seach...
https://acurazine.com/forums/ramblings-12/i-love-tattoos-but-just-wrong-107821/
You can get the stock ones from a honda or acura dealer... the purolator ones I got had 2 filters (all that was needed) for $21.00 or so... Both the dealer and purolator are made by Micron...
Originally Posted by GreenMonster
The stock part number for the cabin filter (same thing as the pollen filter) is 80291-S84-A01, the purolator part number is C15390.
Doing a search here for cabin filter will turn up a bunch of threads.
Originally Posted by elliot
Thanks Green. Any suggestions on where to pick these up in NYC this afternoon? Otherwise, I'll just have them shipped.
re: Purolator C15390:
Purolator did use Micron/Freudenberg as a supplier for the C15390, but now manufactures the product. Purolator does offer some cabin air filters with carbon impregnated media depending upon the application, but does not have a charcoal version of the C15390 at this time.
Tom (Filter Hot Line of Purolator Corp)
It's Always Shabbat
Originally Posted by jipper
When and how often does the cabin filter need to be changed?
Manual says, as you know, every 30K after 60K.
It's Always Shabbat
Ravin,
Well, I'm in Morris County right now, but I'm headed to Manhattan later and so if I could pick it up there, I would. Perhaps it'd be cheaper to order them than pay NYC prices.
It's Always Shabbat
Originally Posted by NighthawkBlue
Green I am not dissing the Puroloator filter but just for everyones info I contacted Purolator and :
So nighthawk, is there an alternative to the Purolator that you'd recommend?
http://www.micronair.us/Honda+-+Acura/2 -the higher priced one does seem to filter much better. I'm not pimping it, but its particle filtration is sposed to be much better.
Will type more when i get a break.
Pall brand sound good but where to buy plus it appears they only make for planes?
http://www.pall.com/Aerospace_36271.asp
Anywho a good Q & A on this site.
With some of the killer flus lurking around, ie Sars and Bird flu -finding a kickin cabin air filter may be something for all of us to consider.
I know the ones I bought had been sitting on the shelf for awhile... Box was a little banged up... So I beleive what you're saying about the source of the filters...
http://john-perry.com/acurazine/docu...aintenance.pdf
I got Purolators 2 pack for $21 at pepboys.
The filters with Activated Charcol are pricey.. I'm guessing the $58 is for 2 filters ??
cycdaniel
12-17-2019 10:58 AM
Abe_Froman
09-16-2015 01:27 PM
Skirmich
09-15-2015 06:41 PM
