Difficulty of Icebox install
Way Fast Whitey
How hard is this install? I called Velocity and they said 2-3 hours, and some cutting and rearanging. What have you guys found?
Where is my super sauce?
If you can use a rachet and a screwdriver you'll be fine. It took me a couple hours, but I was going real, real, slow, and was in no rush. It's not difficult, but a little tedious in a few steps.
It's also helpful to jack up the driver corner of the car to access the underside of the Icebox so you can place the horn correctly.
I would not do anything significant inside the car without having a Helm manual nearby. It's helpful to see where things should be and has all the torque settings of most every bolt in the car. It also has instructions for the idle learn procedure and how to bleed the coolant system.
Someone (I think Shawn S) said the Helm manual is the single best mod to buy for this or any car. I agree.
I watch the installers at Garage Kwai install the whole thing from start to finish .. it took TWO guys (both VERY good at what they do) about 2 hours to finish it.
They had to remove the bumper
They had to lift the car up several times to access the underside
There were sooo many screws that came out and then went back in, and there was plenty of improvisation at times... i'm so glad i had it professionally installed for $30.00.
It isn't that difficult, just use common sense. Plus you don't need to remove the bumper as stated in the directions, especially since you don't have springs yet! If I can do it....anyone can.
If you follow Comptech's directions to a 't' then you have to remove the bumper. If you use some common sense and advice from this forum, you don't. Just remove the flap of the undercar liner in the front driver corner -- about three or four plastic clicky thingies and one bolt -- and you'll have direct access to the underside of the airbox area. Jack the car up so you don't have to lie on your back.
guys it took me and Titand19 all of 45 mins. to install the intake in the rain and you can ask Bnavarro cause he passed by when we were doing it
so please dont pay anybody to do such easy work
Originally posted by TL_Type_S
i'm just tellin' you what I saw... that's all i'm doin...
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
The hardest part for me, honestly, was getting those damn plasic pop rivets off the splash guard under the bumper. They were falling apart b4 they would break loose.
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
Moderator Alumnus
Nitin
09-30-2015 08:22 PM
