Differences between 01, 02, 03
Yeehaw
03 was available w/ 6 speed
03 tails have white strip instead of just a square for the reverse light
03 didn't come with road lamps
03 had different rims
not sure but I think 03 had body colored door handles too, and maybe different cup holder?
thats all I can think of...
Yeehaw
Blown is Best
And yes - Auto only prior to 03.
Originally Posted by mrsteve
Search!!!! This topic comes up every 3 weeks or so.
Oh and the '02 had different side mirrors than the '01
CLS 6MT Navi
2003 only
-Anthracite exterior color
-Floormats marked 3.2 CLS, not Acura
-Supposed to have thicker glass in all windows?
-One setting seat heaters on 6 speed at least
-Center console Handbrake on the 6 speed
-Auto up AND Down on driver window, might have been on other years??
-Onstar packaged with the Navigation system
2001 only
- Sundance Gold exterior Color
2001 only
Originally Posted by anothercls
The 03's with the dual setting on the seats must be for the automatics, cause I only have one button.
2003 Acura CL Press Release / Changes for 2003
2003 3.2 CL Luxury Performance Coupe
Summary of Changes
For the 2003 model year, Acura’s goals for the 3.2 CL were to:
• Increase performance
• Update styling for a sleeker, more aggressive look
In support of those goals, the 2003 3.2 CL has received the following enhancements:
Powertrain
• While it continues to come with a 5-speed Sequential SportShift automatic transmission, the CL Type-S now offers a new close ratio 6-speed manual transmission as well. Models with the new manual transmission also feature:
o Helical limited slip differential
o Curb weight of 3446 lbs. (compared to 3510 lbs. for the CL Type-S with automatic transmission)
o Multi-cone synchronizers
o Self-adjusting clutch with dual-mass flywheel
o Short-throw shift linkage
Chassis
• CL Type-S with manual transmission replaces the VSA found in the CL Type-S with automatic transmission with new helical limited slip differential
• New 6-spoke 16 inch wheels (3.2 CL)
• New 6-spoke 17 inch wheels (CL Type-S)
• CL Type-S with manual transmission adds two hydraulic engine mount dampers to counter engine movement
Body
• Front Styling
o Revised grille with body-colored surround
o Revised headlights with black accents
• Rear Styling
o Revised taillight lenses with clear upper portion
o New exhaust finishers
Safety/Convenience
• OnStar is standard equipment on CL models equipped with the Acura Satellite-Linked Navigation System
• Lower Anchors and Tethers for Children (LATCH) System added on outboard rear seats for child safety seat attachment
• Driver’s Dual Stage Supplemental Restraint System (SRS)
• Auto-up driver’s side window
Interior Styling
• CL Type-S
o Models with black interiors receive titanium-look trim on doors and center console
o In models with 6-speed manual transmission, center console redesigned to accommodate manual shifter and hand-operated parking brake
o Perforated leather door inserts
Summary of Changes
Powertrain
Chassis
Body
• Front Styling
• Rear Styling
Safety/Convenience
Interior Styling
• CL Type-S
Registered User
Originally Posted by Jonesi
Side mirrors are different..
Check out the FAQ forum too...
Check out Page #4 of this pdf....
http://john-perry.com/acurazine/docu..._new_items.pdf
Registered User
Originally Posted by N.O.6speed
the dual settings everyone was referring to was the heater, high, and low. The 03 6speed only has one setting on/off.
also some of the later model 03 CL doesn't have the extended 7yr/100k mile warranty cuz Acura supposedly has fixed the tranny problem that the 01,02, and the early 03 models were having.
I now drive an accord....
Originally Posted by rbf351
some reason acura decided we don't need high and low
