Diff between SC and Turbo?
Old Oct 29, 2001 | 02:58 PM
Iridium130's Avatar
w.t.f., mate?
hey whats the difference between a supercharger and a turbo? from what I understand they are both forced induction...
Old Oct 29, 2001 | 03:01 PM
CO-CL-S's Avatar
Re: Diff between SC and Turbo?
A super charger uses the cars energy to drive the compressor (like a fan belt to turn it). A Turbo charger uses exhause gasses to turn the compressor. Super charger takes some of the engine power, but is available all the time. Whereas a trubo charger doesn't use the engine power, but has a slight lag as the exhaust gasses build up to turn the compressor.
Old Oct 29, 2001 | 03:13 PM
Samer007's Avatar
Smack My B*tch Up
Re: Re: Diff between SC and Turbo?
So which one is better ??
thanks
Old Oct 29, 2001 | 03:18 PM
ruvz's Avatar
YOOOOOOOOOOOOOO!
Re: Re: Re: Diff between SC and Turbo?
thanks
Well, Turbo generally has a "LAG"...which means the time that it takes to wind the turbine (which is dependant on your exhaust pressure). An SC has no lag and starts producing boost as soon as you step on the gas (Belts spin faster, turbine spins).
I'd say an SC is better, but turbo's generally produce a larger amount of boost.
Old Oct 29, 2001 | 03:45 PM
pwille's Avatar
One other consideration is that with the turbo, you have moving parts right in the middle of the VERY hot exhaust output, which over time wears out the bearings. Granted, turbos created now-a-days are much better, but I myself would probably opt for the SC just for the reliability standpoint.
Old Oct 29, 2001 | 03:53 PM
CO-CL-S's Avatar
thanks
The one that fits your car and your needs is the best.
Old Oct 29, 2001 | 03:57 PM
Pull_T's Avatar
Well, I'd say the biggest difference between s/c and turbo is cost. Turbocharging is a very expensive proposition. Most applications are 2x the money of supercharging.
(Mind you, I'm talking about naturally aspirated cars and putting on a s/c or turbo here)
Slow98teg
30
Jan 2, 2017 09:01 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
joflewbyu2
Oct 8, 2015 11:16 AM
CLsuperhero
Sep 23, 2015 12:53 PM
DRR98
1G RDX Problems & Fixes
Sep 2, 2015 10:52 AM
