Diagnose this problem for me
Old Dec 22, 2004 | 12:30 PM
NSXNEXT's Avatar
When I put the car in reverse and brake I get a humming coming from the rear. Only happens in reverse and only when I press the brake pedal.
I also have noticed what sounds like something loose in the rear. A dull clunking noise. I have nothing in the trunk that would make that noise. It happens when I go over bumps,
Any ideas?
Old Dec 22, 2004 | 12:34 PM
mclarenf3387's Avatar
I have no idea what the hum could be.
THe clunk may be a sway bar link. Thats what it was in my car, but I had loosened it when doing the spring install. The noise was exactly what you described though.
Old Dec 22, 2004 | 12:37 PM
NSXNEXT's Avatar
Yup, that's what I always tell people when they describe that clunk. I'm still baffled by the brake issue.
Gotta go find my allen wrenches.
Old Dec 22, 2004 | 12:42 PM
If you have a dental pick, use it to clean out the allen key hole. I learned that the hard way. Didn't clean it out and the key wasn't going in as far as it should and stripped the hole. Had to take a air chisel to the link for about an hour to get it off. All the rust that practically welded the nut to the bolt didn't help either.
Old Dec 22, 2004 | 12:43 PM
NSXNEXT's Avatar
Good tip. Thanks. My Comptech sways have been on for several years now, so I'm sure the end link is nice and rusted.
Old Dec 23, 2004 | 09:29 PM
ChadT's Avatar
Spectacular Aroma About
Could just be the brake pads moving around. They are usually resting where they are driven when applied going forward. Whan you hit the brakes in revers they could have some slack before they are caught by the carrier. Don't know exactly what you are hearing though.
Old Dec 24, 2004 | 11:08 AM
allmotor_2000's Avatar
If you put the car in reverse and apply the brake, the only stress is on the tranny and the
rear brakes (front and rear - mostly front). It could be a motor-mount problem (cuz the motor rocks opposite from its usual motion).
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
