Anyone has one of those heat shields? What is best deal out there? Any feedback?
Thanks,
http://www.designengineering.com/pro...sp?m=sp&pid=33
Thanks,
Adventurist.
I dunno if that would work, I'm a bit skeptical. I've seen similar products around. Especially running something like an AEM/Injen, the velocity of the air inside is something to consider with the surrounding engine environment. Whether it would be beneficial to a high degree is what I would say.
EricL, can you chime in?
EDIT: I noticed your last post on the other thread. Hey, maybe it MAY work.
ive done some searches on the subject and i dont know an answer but i will share some of what ive found
Fact: For every 3.3 °C (5° F) rise in intake temperature, air density drops 1%. The hotter the air, the less fuel the computer injects to compensate for reduced oxygen. HondaLogger datalogging software has enabled us to measure intake air temperature under varied driving conditions.
Around town, testing has shown an average drop of around 10 degrees C which is good for around 3 percent power increase. Remember though that 3 percent power increase is difficult to feel. You'd feel a greater change in performance getting rid of that passenger. In certain conditions a 30° C drop has been measured.
Taken from here http://www.hondata.com/heatshield.html
Some will claim that heat from the engine compartment will be transferred through the pipe of the intake system and into the air passing through the pipe, but this is not true. Testing by Sport Compact Car showed negligible change in intake temperature between where it enters the filter and when it passes through the throttlebody. Their conclusion was that the air is passing through the pipe at a high enough speed that it does not have time to pick up any heat from the pipe itself. Further evidence of this is the fact that the Ice Man brand intake system, made of heat insulating PVC plastic, tested at 9 HP while the AEM brand intake system, made of heat conducting aluminum, tested at 12.9 HP. The conclusion is clear that the design of the intake system is more important than what type of pipe is used to make the intake system.
Taken from here http://www.isuzuperformance.com/isup...ch/intake.html
And heres a link to a thread i started a while ago http://www.acura-cl.com/forums/showt...ght=insulation
all i have to say is i got one and i think it helps some, i live in southern Florida and its hot so i am trying anything i can to make up for the heat
the one i got http://shop.store.yahoo.com/racingsu...coairtush.html
EricL,
Just by looking at the following data from 12 mins trip to work. Temp in the morning was around 63F.
Anyway to improve the intake system by keep it cooler? Do you think the thermal gasket barrier or CAI sleeve above work?
here is the data:
here is the data:
Code:
Title : View / Trip Log / Trip 18 / Table Rows : 134 Columns : 6 Column 01 : Elapsed Time [] Column 02 : Speed [MPH] Column 03 : Engine Speed [RPM] Column 04 : Intake Air Temperature [°F] Column 05 : Intake Manifold Pressure [psi] Column 06 : O2 Sensor Voltage (B1, S1) [V] 0:00:00 0 1149 59.0 5.5 0.97 0:00:05 0 1149 59.0 5.8 0.97 0:00:10 0 1169 60.8 5.9 0.96 0:00:15 2 1289 60.8 8.4 0.10 0:00:20 9 1169 60.8 6.8 0.96 0:00:25 12 1342 60.8 5.1 1.00 0:00:30 16 1725 60.8 5.1 0.94 0:00:35 14 906 60.8 7.3 0.12 0:00:41 2 1444 62.6 9.1 0.64 0:00:46 12 2060 62.6 10.6 0.80 0:00:51 22 2550 62.6 10.4 0.88 0:00:56 29 2238 62.6 9.3 0.63 0:01:01 32 2155 62.6 6.5 0.07 0:01:06 32 2101 64.4 5.9 0.07 0:01:11 33 1582 64.4 5.8 0.04 0:01:16 32 1000 64.4 5.4 0.60 0:01:22 25 1513 64.4 8.4 0.12 0:01:27 29 2170 64.4 11.6 0.10 0:01:32 37 2260 64.4 11.3 0.10 0:01:37 45 2220 64.4 9.9 0.10 0:01:42 48 2071 64.4 10.6 0.76 0:01:47 48 2081 64.4 10.4 0.70 0:01:52 50 2086 66.2 10.7 0.06 0:01:57 54 2053 66.2 9.9 0.37 0:02:03 58 2053 66.2 9.6 0.07 0:02:08 61 2079 66.2 9.6 0.70 0:02:13 61 2068 66.2 9.7 0.10 0:02:18 61 2079 68.0 9.6 0.45 0:02:23 62 2096 68.0 9.4 0.72 0:02:28 64 2123 68.0 9.4 0.06 0:02:33 65 1953 68.0 11.6 0.18 0:02:38 67 1862 68.0 12.3 0.53 0:02:44 68 1881 68.0 12.3 0.16 0:02:49 68 1909 68.0 12.3 0.10 0:02:54 70 1967 69.8 12.0 0.10 0:02:59 72 1987 69.8 2.2 0.83 0:03:04 69 1853 69.8 3.2 0.06 0:03:09 66 1827 71.6 7.3 0.80 0:03:14 67 1860 71.6 8.0 0.07 0:03:19 68 1901 73.4 8.7 0.07 0:03:25 70 1965 73.4 9.1 0.12 0:03:30 72 2018 73.4 9.0 0.07 0:03:35 74 2064 73.4 8.8 0.18 0:03:40 75 2053 73.4 8.4 0.12 0:03:45 74 2019 73.4 8.7 0.07 0:03:50 73 2027 75.2 9.1 0.78 0:03:55 74 2071 75.2 8.4 0.23 0:04:00 76 2111 75.2 8.3 0.58 0:04:06 77 2138 77.0 8.1 0.68 0:04:11 76 2096 77.0 8.4 0.82 0:04:16 75 2060 77.0 9.0 0.80 0:04:21 74 2037 78.8 10.3 0.06 0:04:26 74 2048 78.8 9.4 0.82 0:04:31 75 2058 78.8 8.8 0.68 0:04:36 75 2064 78.8 9.1 0.47 0:04:41 75 2143 78.8 9.7 0.07 0:04:47 76 2134 80.6 9.9 0.72 0:04:52 77 2100 80.6 4.6 0.68 0:04:57 74 1999 80.6 8.0 0.06 0:05:02 71 1950 82.4 8.7 0.76 0:05:07 70 1932 82.4 10.0 0.58 0:05:12 70 1943 82.4 10.6 0.68 0:05:17 71 1952 82.4 8.8 0.57 0:05:22 71 1964 82.4 8.7 0.78 0:05:28 72 1991 82.4 7.8 0.55 0:05:33 71 1962 84.2 7.3 0.12 0:05:38 71 1945 84.2 7.3 0.82 0:05:43 70 1923 86.0 2.2 0.04 0:05:48 68 1842 86.0 5.9 0.76 0:05:53 67 1866 87.8 8.8 0.55 0:05:58 68 1916 87.8 9.1 0.82 0:06:04 70 1920 87.8 9.4 0.80 0:06:09 70 1922 87.8 7.5 0.78 0:06:14 68 1852 87.8 2.5 0.00 0:06:19 66 1839 87.8 5.9 0.82 0:06:24 68 1930 89.6 10.2 0.64 0:06:29 71 1994 87.8 6.5 0.80 0:06:34 70 1842 89.6 2.6 0.00 0:06:39 62 1658 91.4 9.9 0.70 0:06:45 62 1722 91.4 11.2 0.14 0:06:50 63 1759 89.6 2.3 0.88 0:06:55 61 1625 89.6 3.2 0.01 0:07:00 55 1461 91.4 2.8 0.00 0:07:05 50 1422 93.2 12.5 0.10 0:07:10 53 1461 91.4 7.5 0.85 0:07:15 51 1405 91.4 10.7 0.07 0:07:20 51 1396 91.4 6.2 0.06 0:07:26 47 1066 93.2 3.0 0.00 0:07:31 36 923 93.2 3.6 0.04 0:07:36 31 857 95.0 3.8 0.74 0:07:41 26 1486 96.8 9.4 0.68 0:07:46 29 1142 95.0 4.5 0.92 0:07:51 28 1472 95.0 7.8 0.76 0:07:56 26 1029 96.8 7.7 0.94 0:08:01 27 2668 95.0 13.5 0.80 0:08:07 42 1023 91.4 3.3 0.92 0:08:12 39 878 93.2 3.9 0.64 0:08:17 38 1066 93.2 4.6 0.90 0:08:22 36 1012 95.0 4.4 0.06 0:08:27 19 800 96.8 5.2 0.78 0:08:32 6 676 96.8 4.9 0.18 0:08:37 0 680 98.6 4.8 0.06 0:08:42 0 681 98.6 4.8 0.06 0:08:48 0 677 98.6 4.8 0.07 0:08:53 0 677 100.4 4.8 0.68 0:08:58 0 744 100.4 5.7 0.04 0:09:03 2 1924 100.4 8.0 0.72 0:09:08 18 2226 100.4 8.4 0.83 0:09:13 27 1666 98.6 2.9 0.90 0:09:18 20 828 98.6 3.9 0.90 0:09:23 5 675 100.4 4.8 0.04 0:09:29 0 689 100.4 4.8 0.76 0:09:34 0 683 102.2 4.8 0.70 0:09:39 0 714 102.2 5.8 0.06 0:09:44 0 753 102.2 5.8 0.47 0:09:49 0 724 102.2 5.7 0.83 0:09:54 0 683 104.0 4.6 0.82 0:09:59 0 675 104.0 4.6 0.21 0:10:04 0 684 104.0 4.6 0.80 0:10:10 0 683 105.8 4.6 0.83 0:10:15 0 685 105.8 4.6 0.76 0:10:20 0 773 105.8 7.3 0.90 0:10:25 10 1875 105.8 10.4 0.23 0:10:30 24 1314 104.0 2.8 0.06 0:10:35 17 935 104.0 5.2 0.90 0:10:40 16 851 104.0 3.9 0.10 0:10:45 16 1031 104.0 4.6 0.90 0:10:51 14 764 104.0 4.4 0.83 0:10:56 9 760 105.8 4.2 0.06 0:11:01 4 800 105.8 5.9 0.70 0:11:06 0 780 105.8 6.1 0.07 0:11:11 1 739 107.6 6.1 0.80 0:11:16 1 744 107.6 4.5 0.80 0:11:21 0 722 107.6 4.2 0.72
using this carchip E/X... please read this: http://www.acura-cl.com/forums/showt...&highlight=won
