DEI Reflect-A-GOLD
DEI Reflect-A-GOLD
Has anyone used this around their intake piping? I'm thinking about building an ice box and wrapping the piping with this, but it's gold....
This is the other option I was looking into:
SKU: 010391
A high performance reflector born in the aerospace industry for use in extreme temperature swing environments, this state-of-the-art polymer is extremely light weight and capable of handling continual operating temperatures up to 850 F.
Highly effective material for firewalls, fuel cells, engine covers, under hoods, engine compartment, bulk heads, seat bottoms – anything or area that needs protection from heat.
Reflects up to 80% of radiant heat
Virtually NO clearance needed
Fire resistant adhesive side rated up to 325˚F
Self-adhesive backing for easy install and removal
![](https://www.designengineering.com/sites/default/files/imagecache/product/dei-reflectagold.jpg)
SKU: 010408
Cool-Tape offers a flexible, easy to apply and ultra light weight solution to reflect heat and ideal for wrapping wiring, cables, hoses, fuel lines and covering seams. Made of one mil aluminized material bonded to woven fiberglass, Cool-Tape has a super strong self-adhesive backing capable of protecting up to 2000°F radiant heat and available in two different widths and three different lengths.
Withstands 2000°F radiant heat
Flexible and easy to apply
Strong self-adhesive backing
Secure & seal panels, seal air boxes & more
![](https://www.designengineering.com/sites/default/files/imagecache/product/dei-cooltape.jpg)
Does the P2R intake manifold gasket help at all with this? I can't see it doing much of anything although it claims to reduce the transfer of head from the heads to the intake manifold as well as the TB gasket.... I was planning on purchasing the intake manifold gasket, TB Spacer and TB Gasket from P2R.
I will be ordering this either Friday or Saturday once I sell of some more stickers & fatten the wallet.
I may end up ordering the P2R TB Spacer though. It looks a little better than the OutLaw Engineering's but I'll wait til after it gets delivered. Is anyone else running this?
Elegant TYPE S
08-09-2005 08:06 PM
