Damn She is Bleeding OIL
L@@K
Just Noticed today when i pulled off the parking spot, She was bleeding "not Much but I saw oil Stain(s) enough to convince me". I looked under-neath her and to me it seems like it is coming from the Trans. Not quite sure if it is a Trans. fluid but I'm almst certain that it is Trans. fluid, Besides the Leak Tranny is in good shape and I-hope to be able to fix it by this coming week
Anyway the QN is:
- Does this Happen Oftenly? Anyone ever experience this before?
- Also have any of you Guys ever replaced the Gasket btn tranny assembly and the Engine?.
Gasket Number 6 on the Picture
I'll put pictures up by tomorrow,
Your input(s) will be greatly appreciated.
thanks,
R.
Anyway the QN is:
thanks,
R.
what color is the oil? does it smell like trans fluid?
L@@K
My senses of smell arent that good, But i think it is Trans.
thanks,
R.
Tranny fluid is red so that is probly what it is. I'm guessing it isn't anything big. I would check your tranny drain plug and see if it is what is leaking.
Have you ever changed your tranny fluid? The drain plug is very easy to find. It is the only plug that is just like a socket...you don't use a socket like a normal plug. You have to just use the wrench
ReiDLos, you need to get this figured out quickly. You should probably take it to a shop. If not an Acura dealer, a shop that specializes in automatic transmissions.
LFG RANGERS!!!!!!!!!!!
Originally Posted by LukeaTron
Uhhhh, that's a wild guess which I might call disastrously uninformed.
I would not take any chances with this transmission, that is asking for trouble.
I'm just sayin to check the obvious little shit first. It doesn't cost anything to check the drain plug.
However if a shop checks your tranny only to notice the drainplug is loose they COULD tell you it is a gasket that needs replaced and charge you for that and labor just to adjust the drain plug
L@@K
Alright nothing Big, It was oil coming from the Return Seal set between trans and engine.
Took it to a local Shop bought New Seal from Acura Dealer $15.45 and pus labor $150 got it replaced today, No worries with Trans, Bt*h runs like New.
thank you Guyz, for the input.
R.
R.
L@@K
R.
Thats what I was wondering. $150 to R&R a tranny?????? Wow I need to go to that shop!
That is just an inspection cover and how you remove the bolts for the torque converter. If it is the Rear main (which is a semi common problem on the J32) you will have to remove the trans to get to and to replace a 5 dollar seal.
L@@K
"I know people who knows people who do their JOB right and for a good price"
they removed transmission and mount the seal, i even changed the motor mount.
What makes you so scepticals.
R.
Bro. you dont have to belive it, I got my NHBP painted for $400 "back track my threads" and I just fixed the one on the Avatar for $250...tell me you still dont blv it.
R.
R.
If you are getting this work done for free good for you. I find it hard to believe.
i want a lip..
I just bought 1 gallon (1 gallon base coat 1 gallon pearl) of "quality" (Lessonal)Sealer, White Diamond Pearl and Clear for 388.00 for my S10 project(seen in car talk)
IBankMouse
06-13-2020 12:53 PM
