Cylinder misfire
Old Jun 28, 2004 | 08:26 PM
oneilc's Avatar
Kenpachi Teichou
Cylinder misfire
I was accelerating onto the highway and I punched it (in 2nd gear) to keep ahead of a beamer who was trying to cut me off. I pushed it through 2nd and 3rd and then let off as I shifted into 4th. At that point the check engine light flashed 5 times and then went out. I drove home and checked everything out but nothing looked odd. I drove to work the next day and the check engine light flashed 5 times and stayed on (normal driving, nothing hard). I had it checked out and they told me it was "Cylinder #5 misfire". They reset the check engine light and I havn't had any trouble since then (about a month). I'm assuming that it was just something loose causing the spark to fail. Ever hear about this type of problem?
Old Jun 28, 2004 | 08:37 PM
Chopsie's Avatar
Beware of leakage
First I have ever heard of this. Guess just keep an eye on it. What color is the tranny fluid ?
Old Jun 28, 2004 | 08:52 PM
juice's Avatar
Sounds odd that all they did was reset your light and it has not come back.
Old Jun 28, 2004 | 09:35 PM
JimmyTLS's Avatar
The way misfire codes work is that when a misfire occurs, the ECU stores the code. So even if the misfire does not continue, the code will still be in the ECU, thus triggering the CEL and causing your motor to run rich (which is a safety mechanism the ECU does when something isn't going right, better to run rich than lean). The CEL will stay lit until the code is erased by resetting the ECU. Hope that helps.
Old Jun 29, 2004 | 07:22 AM
scalbert's Avatar
That is not unusual for the '03 6-Speed, but the previous 5AT didn't seem to have this issue. I would chalk it up as a one time thing and let it go. If it re-occurs, change out the plugs and see if it comes back.
Old Jun 29, 2004 | 09:03 AM
OHSOFAST's Avatar
could this be the same thing?
Please check this out...
http://www.acura-cl.com/forums/showt...&highlight=cel
Another AUTO Type S with a flashing CEL.
Old Jun 29, 2004 | 11:38 AM
Pure Adrenaline's Avatar
Dragging knees in
Probably random misfire instead of consistent. That's most likely why they only erased the code and sent you on your way.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
kencepeda
Sep 26, 2015 05:13 PM
