Custom Billet Throttle Body
Old 04-24-2003 | 12:37 AM
allmotor_2000's Avatar
So... I decided that boring out my stock TB wasn't going to be good enough, so I rigged a custom billet aluminum TB. It's a tad over 6mm bigger...
I installed it and it immediately made quite a big difference. However, I am waiting on the intake-manifold... so I didn't port the inlet of my stock manifold. I have no idea about hp gains... but it definately feels stronger from 5K to 7K. I think with the intake manifold... I expect 10-15whp at the minimum.
Picture #1 (installed view):
http://photos.yahoo.com/bc/gunjan_ra...c=ph%26.view=t
Picture #2 (Comparison to stock):
Old 04-24-2003 | 12:39 AM
Zapata's Avatar
Cost Drivers!!!!
wow that's quite a difference.
Old 04-24-2003 | 12:41 AM
Some added notes:
(1) No more cruise-control
(2) No more IAC (Idle Air Control) - this poses a little problem which I haven't resolved yet, but more on that later
(3) Doesn't quite idle perfect (in addition to the IAC issue)... working on this as well
Old 04-24-2003 | 12:42 AM
Another note:
If this poses a big problem for driveability... I will use this TB only for the track - its a 5min job to swap them out, so its not any harder than changing tires, for example.
Old 04-24-2003 | 12:43 AM
Mike's Avatar
I'm shipping the manifold tomorrow!
I have all my porting bits ready
Old 04-24-2003 | 12:54 AM
BlueCLS6's Avatar
ex 6 Speed owner :(
Damn, I was ready to order one too . Keep up the good work!
Old 04-24-2003 | 05:21 AM
mattg's Avatar
70 mm ?
how much does it cost?
Old 04-24-2003 | 08:04 AM
I am RobG's Avatar
im back
where the hell did you get that one? i'd definitely use it for track use
Old 04-24-2003 | 11:11 AM
Nobody makes one for the CL-S... and I know the guy who knows the guy who makes them for several speed shops. If he made one absolutely one-off... meaning it will fit perfectly and have AIC/cruise-control... its upwards of $500.
Old 04-24-2003 | 01:11 PM
Zapata's Avatar
Cost Drivers!!!!
hmmm if i knew for sure that this thing would produce 15hp with manifold work. I'd spend the money.
Old 04-24-2003 | 01:49 PM
I am RobG's Avatar
im back
now my question to you, is where did you get yours? was it an upgrade from the accord v6 and you fabricated or what
Old 04-24-2003 | 01:52 PM
Loosely based on the accord V6... else its very expensive to have it CNC'd from scratch!
Old 04-24-2003 | 01:58 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Now is it POSSIBLE to port the stock TB to 70mm?
Old 04-24-2003 | 02:22 PM
Stock TB can go about 3-something mm-over MAX! Ours are relatively thinner than usual B-series or H-series motors...
Old 04-24-2003 | 03:21 PM
CLS2001_97124's Avatar
Revving at 9K...
With more air coming in, did the ECU have problems adjusting the air/fuel ratio so you get a smooth acceleration? or do you think if you get a VAFC(?) would help?
Old 04-24-2003 | 03:28 PM
I am RobG's Avatar
im back
a lot of times just unplugging the battery overnight helps reset the ECU, that may just be a rumor but when i did that i noticed a lil difference
Old 04-24-2003 | 05:13 PM
Esrunyzarc's Avatar
Mirical Whip not Mayo..
All I gots to say is sweet.... Keep up the good work allmotor let us kow when all the bugs are worked out....
07-16-2017 08:33 AM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 10:09 AM
