Cusco upper strut bar
Got the Cusco upper strut bar Friday and had it on since then. Initial impressions? Well after hitting some mini-twisities, it seems that in general any upper strut bar does actually help. I felt somewhere between a 10%-15% change in stiffness. I was able to take freeway entrances (the nice ones that twists around) at a faster speed with higher control. So definite improvement in entrance speed. Unfortunately, coming out of the turn, I still can't come out as fast...hopefully the CT sways will fix that ...and maybe some better gripping tires. The Cusco bar is from blxmjx.
are there any other colors the cusco bar comes in?
where did you order it from and where do you get info on the cusco stuff? i've looked everywhere and i can't find any source of info on what they have for our cars.
Busy Living
I put the Neuspeed on this weekend and noticed similar behavior. Mine may have been a more drastic imporvement since my stock strut bar needed to be tightened. The bolts where very loose, like over a full turn each bolt.
lanechanger
10-13-2015 10:56 AM
adreano17
09-29-2015 08:48 AM
