CT Icebox CAI or AEM/Injen CAI
So I'm going to be placing an order for a CAI within a week or two. I'm torn between getting a CT Icebox or picking up a CAI from AEM or Injen. I like the AEM & Injen cause it can offer performance and kind of shine up the engine bay.
Does the CT Icebox offer any real advantages over AEM/Injen?
No it does not. If you want a BADASS intake this is what I did: https://acurazine.com/forums/showthread.php?t=194366. But, if I could do it again I would probably just get an AEM/INJEN.
Since we're on the subject of CT and I see it listed in your sig, how do you like your CT springs? How much of a drop did it give you?
TCM 01 CL-S
I have a question, I'm not sure how to read that last chart, Air/Fuel. It seems the A/F goes down with the CT. Would this allow for better gas mileage than the P2R set up?
Also, If I went with the CT, would the P2R TB spacer and Plenum still work, or would I have to go stock intake or P2R intake?
stickgoat
I like the CT springs, there nice and stiff, feels good on corners and at higher speeds, but I think im going to get something else. I've ridden in my friends CL-S and he has Tein SS. I think I'm going to grab those with the EDFC controller. This will allow for a wider tire, 235 instead of 225. plus give me some options here in New england with going from smooth to rough road all the time.
stickgoat
stickgoat
Uses turn signals in my
TCM 01 CL-S
If you went with the CT (or any other intake for that matter), you could still use the plenums with absolutely no issue (thats how I had my car for several months). You could also use the TB spacer with the CT, but from when we looked at it, it seemed like it may be necessary to slightly trim one of the connections between the throttle body and the icebox itself. The P2R intake is designed only to work with the TB spacer.
lanechanger
10-13-2015 10:56 AM
Nitin
09-30-2015 08:22 PM
