Crazy Question
6th Gear
Crazy Question
Its a some what of crazy question whats the diff between the auto heads an the 6spd heads. I kno the TB is diff . Is it the cams an timing like in most.
correct me if im wrong but there is no diff between heads on 6spd and heads on auto. there are probably some small timing adjustments, maybe even bigger cam lobes, or an extra tooth on the gear, but otherwise I think they are they same specs.
There is nothing different (other than the front cam gear for the timing belt due to the different TDC sensors). The TB is the same as well. Only difference is the auto has the VSA tb the manual doesnt.
6th Gear
{Its a some what of crazy question whats the diff between the auto heads an the 6spd heads. I kno the TB is diff . Is it the cams an timing like in most.}
Thanks for the info. I was asking to figure out if there was anything extra needed to do a 6spd swap other than the main parts
Why didnt you ask that to begin with. ALl depends on what your planing on swapping. (ecu etc...)
If you go that route you will need (like stated in the swap thread here, and in my conversion thread in 2gTL) lower timing belt gear, crankshaft position sensor, front cam gear, TDC sensors.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 09:00 PM
