Couple of mods for the near future
Ill be finally getting some decent weather here in MN i might be able to do some work on the car, couple of mods, and standard maintainence Over the next month or so i will be adding
polished lower manifold runners picked up at a junkyard for super cheap
Pnp throttle body
valve cover gasket
o ring for power steering pump...again!
and i have acura legend 2 piston calipers on order
here are a couple of pics of what i have going on so far
Pnp throttle body
valve cover gasket
Update i have finished earlier than expected. I only ran into a couple of problems which i was expecting broke 2 fuel injectors removing them from the lower runner and the TB that I polished had broken piece of plastic where it holds the throttle cable in its spot so i had to swap mine off of my car and onto the new one. I also went a head and did another polish with a rotary tool and a drum sanding bit in the IM only because the first time i did it i didnt do a very good job so i cleaned up my work a lil bit. So now the only thing inhave left to do is the legend brake caliper upgrade probably in the next couple of weeks but i was able to get the hard stuff out of the way for now, i will probably go back later this year and replace the last 3 injectors after taking everything apart this car is surprisingly easy to work on, so here are some pictures i tried to remember to take while doing this
Broken injector 1
Looks a little bit better
The TB installed
Cleaned the egr port
Put the back runner on while waiting for parts to come
Dirty
Most of everything reassembled
Fuck this bolt haha
Still not the best but better than before
Broken injector 1
The TB installed
Dirty
Fuck this bolt haha
Nice!
The broken piece on the TB may be the cruise control cable. Mine broke but instead of a new TB I used some wire to keep it captive. I worry about it but years have gone by.
Im getting ready to have headers and new exhaust installed, cai I’ll do and in the back of my mind have a Ron Jon body kit installed.
What do you know about a bushing kit or like an energy suspension kit? I would have a shop do it which will probably be expensive.
You planning on a turbo or SC?
Keep postin’ - I’m followin’
mattcl-s (05-03-2018)
Nice!
turbo? Nah engine has over 200xxx im just keeping it running and doing simple and subtle mods
I am going to do the legend brake caliper upgrade in the next couple of weeks that will be my next mod
I just searched that. Nice DIY. I had a 2dr 1990 legend 5sp before the CL. My dealer is having a timing belt job special (water pump, tensioner, etc) for like $1700. The car has over 220k miles and I did it once around 110k like 6 years ago. Think it’s time to do it again? I’m trying to prioritize. The Ron Jon kit keeps falling to the bottom of the list.
I ordered some 2003 smoke headlights on the marketplace on here this week and am waiting for them to arrive.
Im back! I took along break there doing these mods i said i was going to do well...I got around to doing the Legend caliper upgrade easy install and haven't had any issues yet
I got around to doing some more work on the CL during the winter months here a few photos from the progress
Tein street advance z coil overs
Rpf1 17x8.5 40mm
bfgoodrich sport comp g2 245/45/17
New valve cover gaskets and intake manifold plenum gasket set
I wasnt happy with the way i painted the valve covers the first time, so i removed all the paint and re did them with VHT wrinkle red it turned out much better. I also spray the intake manifold with VHT silver metalic but it turned out more blue....oh well it dont look bad. Now the snow needs to melt so i can take this thing for a rip its been way to long of a winter here
Rpf1 17x8.5 40mm
whenever you get a min could you get more shots of the valve cover/intake mani... i'm super digging that silver/blue ,,, I like the silver/blue and the offset black pieces..
AbovePrime.
10-16-2007 10:42 AM
SilverCL225hp
09-18-2002 10:57 PM
