Could It Be...'03 Tranny Was Fixed?
Do it! U Only Live Once!
I've posted 2 threads in the past couple of months asking if any members had trouble with their '03 automatic transmissions. So far, not 1 Member has come forward to complain. I know the statement from Acura said "some" 2003's" might fail, but it appears that the problem might have been fixed.
Hmm
Who knows PAP.... maybe none of them have enough miles on them yet.... I dunno... but don;t worry if it happens I am sure you will hear about it here first...
Smitty
Smitty
go like hell
1 Post
my dad works for Honda of America( Anna Engine Plant)(AEP), he said for the 03 CLs and TLs (which were the main 2 with nukeing trannys) they redesigned the transmissions. matter of fact if you have a one go in under warrenty they bolt in a 03 transmission because there was a design flaw in the 01(?) and 02. from what i've heard the shavings from a "pack"(which is a part in the transmission) bearing was grinding against the bearing which caused metal shavings(i know duh) this went down into the ATF oil pump and it would clog the intake part which would nuke the tranny
Re: Hmm
Smitty
Smitty
Find beauty in dissonance
Re: Re: Hmm
Originally posted by Pappy
You may be right Smitty. What's the average mileage for the breakdown?
Originally posted by SilverBullet
A good handful of 03 TLS have had the tranny die on them.
I would actually go out on a limb to say that I've read almost as many '03 failures as the original 00-02 TL's. Some are failing with very low miles, some in the 10k-20k range, etc. There's no real pattern yet.... but there are definitely failures on the 2003's.....
Didn't the 2003 CL's and the 2003 TL's debut at different times this year??
AND, an excerpt from the Honda site that has the warranty extension anouncement:
"Vehicles covered by the extended warranty include:
* 2000 - 2001 Honda Accord, Odyssey and Prelude
* 2000 - 2002 and some 2003 Acura 3.2 TL
* 2001 - 2002 and some 2003 Acura 3.2 CL
Honda Warranty Extension News Link
Perhaps a tally of people with BOTH 2003 TLS and CLS vehicles THAT are being refused the warranty extension by build date and/or VIN might be useful.
Re: Re: Re: Hmm
Originally posted by Bluto
Not sure of the average. Some have failed with less than 5k. I think some members a pushing 75k with no problems. The mileage is too diverse.
second at 29,500
great replacement
11,000 miles!!!!!!!!!!!!
i have never replaced an auto in 34 years of car ownership
welcome to tranny hell
When mine started giving me problems, i took it in, and they tried 3 (!!!) different '01 trannies, and none of them worked. They even replaced the ecu, but no go. Finally they gave up and used an '03 tranny, and it runs like silk, and shifts better than the even the first one [knock on wood].
