Comptech sways...
Old Feb 16, 2003 | 09:31 PM
peiqinglong's Avatar
Comptech sways...
I finally got my Comptech sways...woot! Now I got some questions. First off...what's the torque settings? How do I get rid of the squeaking thing that people mention they have with Comptech sways. I recall the solution was teflon tape, but recall there was a new solution. Thanks people!
Old Feb 16, 2003 | 09:42 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
teflon tape!
Old Feb 16, 2003 | 09:58 PM
acuraboy_RENAMED's Avatar
some people just used regular grease to quiet the squeaking...nothing exotic
Old Feb 17, 2003 | 12:28 AM
Red Rider's Avatar
Subie Dubie
Gotta get you out to test them in the Twisties
Old Feb 17, 2003 | 12:41 AM
oghondaman's Avatar
Grease,Tape wears out too quick.
Old Feb 17, 2003 | 12:59 AM
Allout's Avatar
Blown is Best
Re: Comptech sways...
I believe it's 28 ft lbs on both the front and rear sway bar bushing brackets. Not sure of the torque on the end links but firm with 3/8 drive should be more than enough.
I just used the teflon tape and put multiple layers - no squeaking yet.
With your strut bars, your car should run like it's on rails. Tear it up!!!
Old Feb 17, 2003 | 11:23 AM
Almost ready
Old Feb 17, 2003 | 11:30 AM
Gilgamesh's Avatar
peiqinglong enjoy em they rock ass...just did em on my TLS. And the neuspeed upper strut bar...its handles like I never knew it could.
Old Feb 17, 2003 | 11:42 AM
Oh another question people...how hard is it to do this with jack stands and a jack?
Old Feb 17, 2003 | 12:49 PM
BC's Avatar
BC
nearsighted visionary
If this OFG (old fat guy) can do it, you can too. Took a bit of putzing around to get the front on. But it'll go.
Old Feb 17, 2003 | 01:28 PM
Gilgamesh's Avatar
Yeah its easy enough...til now I had done only routine maintenance. I just did em and its sooo easy. hour thirty for the fronts (figured out what was going on) and 45-60 mins for the rears. And I did it on stands, fronts went all the way up, rears only about halfway.
Old Feb 17, 2003 | 04:51 PM
mr. big's Avatar
Its easy, i installed them myself that way. and its the first mod i ever installed myself
As for squeaking, i first taped the bar with the teflon, then covered it with grease...so i used both. U dont wanna wrap too much tape because then the bar will not be fastened as tight as possible to the bracket.
Old Feb 17, 2003 | 05:15 PM
jucee187's Avatar
PACDAT
can someone please post pics of this taping process.. where exactly do you tape it?...
Old Feb 17, 2003 | 10:26 PM
mr. big's Avatar
u put tape over the area where the bushing goes....Before u put the bushing on, tape the area where it would go and then, put the bushing on....but dont put too much of a thick layer, then it would not be a tight fit...i just wraped one layer of teflon tape, and then lubed it with grease, then put the bushing on right on top....hope that helps
Old Feb 17, 2003 | 10:32 PM
beerknurd's Avatar
Busy Living
For those that put the sways on themselves, was the front bushing polyurethane or rubber? I have stock sways for now, and I got polyurethane front bushings and when I went to replace them, the stock fronts seemed to already be poly, so I didn't swap them.
Old Feb 17, 2003 | 10:34 PM
synth19's Avatar
I have tried WD40, and that lasts for maybe a week....... what kind of grease are you guys using that would last longer without using the tape?
Old Feb 17, 2003 | 10:41 PM
DeezNutz's Avatar
2ManyMiles
my rear sway's squeaking too. the teflon tape wore out. i'm quite anxious to get rid of that annoyance. standard automotive grease will do???
Old Feb 17, 2003 | 11:16 PM
I talked to Comptech today and they said just use Teflon...they no longer use the grease.
Old Feb 17, 2003 | 11:26 PM
bc01cls's Avatar
Stops Squeaking Now
After the dealer's silicone grease wore out I used Dow Silicone Spray..........Prestone's is good too. A couple of squirts on the bushings and I haven't heard a "peep" in months!! Try it!
Old Feb 17, 2003 | 11:31 PM
mr. big's Avatar
i used both tape and grease
Old Feb 17, 2003 | 11:34 PM
mr. big's Avatar
mine only came with poly for the rears...and i used the stock ones for the front...they are rubber
Old Feb 17, 2003 | 11:38 PM
DeezNutz's Avatar
2ManyMiles
i had my installer do tape only, and it was squeaking within a couple months. i can see where it's worn away. i would highly recommend tape and grease for anyone who is installing it. i'm gonna pick up some Dow Silicone Spray ASAP!
Old Feb 18, 2003 | 11:08 PM
synth19's Avatar
Re: Stops Squeaking Now
thnx for the tip, best place to get this spray?
Old Feb 19, 2003 | 08:13 AM
bc01cls's Avatar
auto parts store..........
I've had the can of Prestone so long, but I remember buying it on the road in an auto parts store. Stuff works great at stopping rubber seal squeaks around doors, and winter squeaks from plastic panels too. The Dow I got from a medical supply warehouse years ago.
Jul 16, 2017 07:33 AM
BoricuaTL
Apr 8, 2016 01:08 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
k6biv
Sep 22, 2015 02:06 PM
