Comptech Header claim?
Old Nov 13, 2002 | 08:34 AM
TKO's Avatar
TKO
Is this additional 32HP that they claim here true? What does the CL actually put down to the wheels stock? Acura says 260hhp but, is this accurate? What does a CL put down with a comptech header, exhaust and cold air intake alone?
Polished stainless steel headers & downpipe
32hp<<< maximum gain, increased power from 4000 rpm
for years: 2001-03 CL and CL Type S (including 6-speed)
installation time: 2-3 hours
CARB legal
Old Nov 13, 2002 | 08:43 AM
juniorbean's Avatar
Acura says the CL puts out 260hp... that is at the crank. All car companies report crank HP, not wheel HP. The CL-S is putting down about 195-205HP to the wheel. Most dynos I've seen are in that range, which is accurate when you factor in the 20-25% power loss in the tranny.
The Comptech claim is pretty much true. The most I've ever seen dynoed was a 28hp gain to the wheels, which translates to about 33-35hp additional at the crank.
With all 3 mods you listed you're looking at about 230-240hp or so to the wheels. Headers add about 28hp, intake about 6-8hp and exhaust about 1-2hp.....
All of the above numbers are referring to the automatic transmission.... the 6-speed CL-S would have slightly higher total numbers.....
Old Nov 13, 2002 | 08:45 AM
I am RobG's Avatar
im back
i dunno how maybe my car's on steroids but i got a 247.6 with intake/exhaust/headers/and plugs and it was lke 65-70 degrees out so i dunno. And the stock was like 206ish so i got about 40ish to the wheels
Old Nov 13, 2002 | 08:46 AM
juniorbean's Avatar
Here's some reading for you. It starts with the headers and rolls into CAIs....
http://www.geocities.com/gamesmgr/chod/acura/#Header1
Old Nov 13, 2002 | 08:47 AM
juniorbean's Avatar
Well, you also have a 6-speed which should be putting about 10-15 more HP the wheels....
I've edited my reply to indicate I was referring to the auto....
Old Nov 13, 2002 | 08:52 AM
I am RobG's Avatar
im back
ahhh good call
Old Nov 13, 2002 | 09:07 AM
TKO's Avatar
TKO
Thanks for the replies guys....thanks for the FAQ juniorbean!
Old Nov 13, 2002 | 11:54 AM
Water-S's Avatar
go like hell
i'd say a CL-S(01-03) witch C/T headers you'll be in the 300 HP range. (that's at the crank)
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
rangomango
California
Sep 24, 2015 05:47 PM
k6biv
Sep 22, 2015 02:06 PM
