Comptech Flywheel... clutch BROKEN!!
#81
Lives On BOOST
Originally Posted by Accord_V6_400m
Seriously, I mean why take the chance? that would be like me reusing the original timing belt that came on the junkyard motor that I used for my swap. Not worth the savings. Anyway when you get it done we should meet up so I can see how it is.
I've driven a few setups, but im just forgetful I guess. I want to see how the clutch engagement compares.
#82
Lives On BOOST
is this the throwout bearing?
http://catalog.autohausaz.com/autoha...bl3fyqbenufhqb
#83
Lives On BOOST
Are these good prices for the pp and throw out bearing? ^
#84
Blown is Best
Originally Posted by krisdlm
Hope the setup works well, good looking. So I still need a pp and a throw out bearing? Anything else? Where can I get this stuff anyway b/c i know the oem clutch comes as a set? Can you buy this stuff separately?
http://oemacuraparts.com
And no - they do not sell the PP separate from the friction disk. That's why I have two new ones laying around. You'll buy the set and just use the PP.
#85
4drs just wanna have fun!
Originally Posted by Allout
I think these guys have good prices on OEM parts.
http://www.oemacuraparts.com/partloc...layCatalogid=0
#86
Lives On BOOST
#87
Lives On BOOST
is the release bearing the same as the throwout bearing?
#88
Blown is Best
It seems as if you can buy the friction disk by itself about 135 shipped:
$156.85 for the pressure plate. I think I paid a little over 200 for the PP and Disk..
#89
Blown is Best
#91
http://img168.imageshack.
here's the update on my car! It turns out that not only did I fucked up my Flywheel/clutch/press. plate & crank sensor, my crankshaft was bent. It looks like the flywheel tweaked to the right ( if ur facing the engine) and bent the crap out of it. My homie was able to replace the clutch/flywheel for about $500 for parts/labor but he wasent able to replace the c/shaft, so I had to tow it to the dealer. The guy at the dealer told me to replace the the bent c/shaft it will be a $4,000 job becuz they have to take apart the engine. For $600 more he told me they will replace the whole bottom block and I'll practicaly have a new engine. Luckily I was able to get a "discount" and got the job done for $4,200. I will NEVER! put a light flywheel/ clutch on car agein!!!
#92
Why not just get a used J32 engine?
#93
Cuz I figured I'm practicaly getting a new engine and getting a used one can be risky. My engine is well taken care of so I know I wont have any problems with it down the road.
#94
any other fortunes or misfortunes with clutch & flywheel with the CLS6? Is the kit still the way to go? They have three different choices for the CL on their website... I might be buying an '03 and in case the clutch is shot I'd like to know what options are available
It sounds like going with comptech (if they even still sell them...) is a mistake based on the poor experiences by salcls and the original poster.
#95
I Wanna Beer
Best way to go is with the factory clutch unless you're running a boosted application. Even with low boost the factory clutch setup is just fine.
#96
Lives On BOOST
#98
Blown is Best
The lightweight flywheel doesn't add additional capacity but adds drivability and faster revs. I like my setup and would not hesitate doing it again.
#99
6speed
this may have already been answered but would it be ok to use the UR stock size pulley and comptech flywheel? im assuming the UR pulley in the previous posts is the underdrive pulley.
#100
Blown is Best
Both UR pulleys would cause the problems with the Comptech flywheel/OEM pressure plate. It's more related to removing the dampening from both ends of the crank and causing too much shock for the stock pressure plate to handle.
#101
i only know of this one instance , i dont think its been determined that having both was the real problem...
#102
Blown is Best
#103
6speed
#104
Blown is Best
Take a look at post # 50, 52, and 76 in this thread. I don't think we'll find conclusive proof but these indications are enough for me.
There are quite a few problem free Comptech Flywheel users out there - ThinJim being one when he put down 460whp with his Turbo Kit. My clutch is still running fine too. Most of the problems I've heard of relate to using lightweight crank and flywheel.
#106
*** Sorry to post in a old thread ***
My clutch is broken so i bought the new oem kit (clutch + pressure plate) along with the clutch bearing...
BUT.......
My OEM flywheel is going to be resurfaced tommorow... and i bought the UR crank pulley...
When you resurface the flywheel, it remove some weight... do i will have problems with the UR pulley??
BUT.......
#107
BUT.......
BUT.......
#109
#110
#112
MP90 uninstalled
Dont use the lightweight flywheel with the lightweight crank pulley or the clutch/flywheel will be destroyed. Only use one or the other. I hope your read the whole thread before asking that. If you didnt take the time to read it, I might be wrong.
#114
I still think its unproven that the UR pulley + comptech flywheel caused the problems on my car. Crank was not warped, nor were the main bearings overly stressed once I took the motor out.
#115
THE J35A2...
I blew my piston though, which i blame the lack of tuning when everytime i open up my EEC...
#116
Blown is Best
#117
Blown is Best
Don't be a stranger and hope you stick around. Your advice is missed around here.
#119
I've heard that if you look in the owner's manual, there's a section that you list the actual replacement of each transmission along with the mileage, serial #, and date of replacement. Disposable transmissions???
SidhuSaaB
05-30-2020 12:40 AM
