comptech flywheel
Old Nov 21, 2009 | 07:35 PM
silver6speed's Avatar
Registered User
comptech flywheel
Im curious is there anywhere u can buy the flywheel seperate. All i see is the clutch/flywheel combo for 1400.
Old Nov 21, 2009 | 07:40 PM
Rajca's Avatar
wham bam thank you ma'am
CM is cheaper
Old Nov 21, 2009 | 08:28 PM
Allout's Avatar
Blown is Best
http://www.ct-engineering.com/store/510130.html
The CT Flywheel is only the flywheel and friction disk. Keep in mind that you'll still be using the stock pressure plate.
Old Nov 21, 2009 | 11:02 PM
Registered User
Yea i read the thread posted on the TL forum by Jose05tl. He is using the spec stage 2 clutch with the comptech flywheel. i thought i read ppl had issues with the CM. Id prob go with stock or comptech, with the spec clutch if i did anything. Even with the spec clutch im betting from pic that the PP is full stock just painted.
Old Nov 22, 2009 | 12:21 AM
civicdrivr's Avatar
Ive read alot of bad reviews about the Spec clutches.
CM had issues with the flywheels, but supposedly they rectified those issues. Im waiting for my setup which has been on BO for the past 2 weeks. It is supposed to ship next week.
Old Nov 22, 2009 | 10:13 AM
Rajca's Avatar
^what stage u getting?
Old Nov 22, 2009 | 10:45 AM
Registered User
Keep us posted pls. Ill stay stock till something is tested.
Old Nov 22, 2009 | 12:38 PM
civicdrivr's Avatar
that would give away my goals
Will do
Old Nov 22, 2009 | 12:51 PM
Pinho's Avatar
http://www.aascomotorsports.com/ its what i have,clutch masters and other companys uses this company to make them
Old Nov 22, 2009 | 05:10 PM
civicdrivr's Avatar
Out of curiosity, are you having any issues with it?
CM has been having issues with the flywheels. Apparently they are short 1 tooth and not spaced correctly so they are causing premature failure to the starter.
Old Nov 22, 2009 | 05:11 PM
fuzzy02CLS's Avatar
I thought CT killed the clutch/flywheel months ago?
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
k6biv
Sep 22, 2015 02:06 PM
TxRzrBk
Sep 17, 2015 01:07 PM
