Comptech Clutch/Flywheel installed
Old Jul 5, 2003 | 04:26 PM
allmotor_2000's Avatar
Took 4 hours... quite a pain actually... need to remove the entire front subframe!!
Feels great... more seat-of-the-pants difference than the Comptech Header.
I rented some time and tools at my friend's shop... so it only cost me $100 for the install.
Car feels great except that its 105 degrees out here today!!
Old Jul 5, 2003 | 05:11 PM
typeR's Avatar
Re: Comptech Clutch/Flywheel installed
lets get that thing to the the track my firend
Old Jul 5, 2003 | 05:32 PM
darrinb's Avatar
///M POWER
damn thats sweet, your def in the low-mid 13's now
Old Jul 5, 2003 | 07:53 PM
Yeah.. it will be interesting at the track... although we'll have to wait and see regarding E.T's.
The stock flywheel is weighs a ton!! Revs drop much quicker and pickup equally fast. Idle changed about 300-400RPM, so that's a pretty hefty load off the crank.
Anybody else planning this mod? I can suggest a few things to make installation straightforward - although I wouldn't recommend this to be done at home because doing this under a floor-jack and jack-stands would be horrible!!
Old Jul 5, 2003 | 08:28 PM
power3dfx's Avatar
Parting out 02 Type S :(
congrats on the new hp gear.
imagine if you had the flywheel installed when the turbos were spinnin!
Old Jul 6, 2003 | 12:11 AM
darrinb's Avatar
///M POWER
yea, titand needs em too
Old Jul 6, 2003 | 01:22 AM
scalbert's Avatar
Don't scare me away from doing in the garage, my back is in fine shape to allows easy access to and from the underside of the car.
Anyway, great to hear you got it in. Please keep us updated on the response and the changed aspects.
Old Jul 6, 2003 | 01:44 AM
It's definately do-able at home... just might be a pain. It will help to have an extra set of hands... this tranny is pretty heavy as well. The basic removal is pretty standard to any fwd transverse-mount motor-setup, except for that front subframe. The front stabilizer arms need to be removed (driver-side) and of course the subframe... I just think it will be tough to do this with the car on jack stands.
I drove the car this evening when it had cooled down a bit... boy it feels good!! 2nd gear is STRONG... 1st is non-existent... it spins to redline each and everytime from 3K onwards... you can nudge the throttle until... say 5K and then floor it and the tires light up.. very similar to the turbo except for instant response.
The clutch has a slight shudder... probably the material type... clutch feel is about the same, although it appears to catch lower in the pedal travel.
3rd chirps nearly everytime now... the sound depends on the road surface.. some elicit a nice "chiirrrp" while others just causes some tire spin without sound.
I haven't done a hard 1-2 shift yet as I want to break the clutch in a little more.
Old Jul 6, 2003 | 01:46 AM
Might need to make another kit! Or try some N2O someday.
Old Jul 6, 2003 | 06:10 AM
Zapata's Avatar
Cost Drivers!!!!
hmmm awesome, i'm planning this mod but not until next year.
Old Jul 6, 2003 | 07:10 AM
mattg's Avatar
do it...direct port 150 shot...do it
Old Jul 6, 2003 | 12:16 PM
Is that some type of subliminal message
I'll run the car first... then depending on how it runs, I'll go appropriately. If the car runs like a mid or high 13... then I might choose that route... if it runs low 13's... then it might be relatively simple to get into the 12's. After this a > 0.5s improvement will require internal engine work.
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
BoricuaTL
Apr 8, 2016 01:08 PM
k6biv
Sep 22, 2015 02:06 PM
TxRzrBk
Sep 17, 2015 01:07 PM
k6biv
Sep 10, 2015 06:37 PM
