Comptech B Pipe Dent Fixable?
Old Oct 14, 2013 | 12:24 AM
o0o0o0's Avatar
Finally Registered
I'm looking to by a full Comptech cat back by the b pipe has a dent in it, Will having a shop cutting the section out and replacing it mess up the b pipe?
Sorry for the double post Ron, but no one really looked at me thread in the Problem and Fixes thread.
Old Oct 14, 2013 | 07:58 AM
gnuts's Avatar
3.5 psi
I don't see why that wouldn't be fixable.
Old Oct 14, 2013 | 11:05 AM
o0o0o0's Avatar
Finally Registered
Hey Gnuts, what do you think the best way to fix it? cutting the pipe and getting a new piece welded on?
Old Oct 14, 2013 | 11:23 AM
gnuts's Avatar
3.5 psi
I'm no expert, but I would think that would be the easiest way. Might be easier for the shop to install it then cut in a new section to make sure it's the proper fit and length.
Old Oct 14, 2013 | 11:28 AM
TheWeez's Avatar
I Wanna Beer
No reason they can't cut it and replace it. Really, it's not even in need of being replaced. That little bit won't stop the flow.
Old Oct 14, 2013 | 08:24 PM
03 tls nc's Avatar
I agree with Gnuts it should not be that bad to fix. Install the hole set up and take it to a good muffler shop. I don't think it would cost more then $100 - $150 to be replaced with SS tube. I would make sure the use SS for the repair.
Old Oct 22, 2013 | 03:32 PM
o0o0o0's Avatar
Finally Registered
Ok I was thinking of the same thing. Thanks guys.
Old Nov 4, 2013 | 01:17 PM
o0o0o0's Avatar
Finally Registered
do I need a gasket for this b pipe to connect to my stock cat?
Old Nov 5, 2013 | 06:40 AM
fuzzy02CLS's Avatar
Yes. A stock gasket will work. Or a perm-a-gasket.
I wouldn't mess with that. I'd throw some high temp black paint on it & be done. That doesn't look like it will have any problems with flow & it more cosmetic.
Old Nov 12, 2013 | 11:30 AM
o0o0o0's Avatar
Finally Registered
Should I do a ecu reset after I install the catback?
Old Nov 14, 2013 | 07:11 PM
aznboi2424's Avatar
Won't make a difference.
Old Nov 14, 2013 | 07:51 PM
o0o0o0's Avatar
Finally Registered
That's what I thought. I bought this exhaust basically for sound lol. I already knew there was not going to be any performance gains. I think I got a great deal on them though.
Old Nov 19, 2013 | 03:27 PM
aznboi2424's Avatar
Hopefully it will increase the sound a bit. I had the Comptech axlebacks and they sounded good but a bit too quiet for me.
Old Nov 19, 2013 | 06:50 PM
o0o0o0's Avatar
Finally Registered
I got them installed. I installed the axleback first because I knew it was easy and fast. Took me 30 minutes at most. They sound great but it was a little quiet. Then a week later I added the b pipe and this increased the sound a little more. Now its a perfect for me. I really enjoy the sound.
Now I need performace. I guess the only thing next for me is headers. I want to find a icebox to replace my aem cold air.
Old Nov 20, 2013 | 02:55 AM
o0o0o0's Avatar
Finally Registered
When I was installing my b pipe I could hear something in my resonator. It sounded like pieces of sand or dirt in side. it only made sounds when i tipped it or shook it. I try to tip it to its side to get it out but nothing came out. I went ahead and installed it. Should I be worried of it getting into my engine?
Old Nov 21, 2013 | 03:05 PM
aznboi2424's Avatar
Should be fine, might be some sand or something but it wouldn't travel all the way up into your engine. Exhaust gas only flows one way.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
Rcelestino93
Sep 23, 2015 10:01 PM
