comptech b-pipe
Old Dec 17, 2009 | 07:53 PM
brian6speed's Avatar
Lone Wolf
comptech b-pipe
Just wanted to ask if anyone knows if the comptech b-pipe for the 01-03 tl fits the 01-03 cl or is it a different part? I tried emailing comptech but havnt gotten a reply. Hard to find info on this since item is discontinued.
Old Dec 17, 2009 | 08:32 PM
Allout's Avatar
Blown is Best
If I recall it's different between the TL and CL version of the B Pipe. I'm pretty sure the CL is shorter.
Old Dec 18, 2009 | 07:09 AM
RooEng's Avatar
I have a tl b pipe on my cl. I had to cut about 2" to make it fit. Otherwise everything else is the same.
Old Dec 18, 2009 | 07:28 AM
Lone Wolf
ah thats what i was thinking the tl would be longer since cl mufflers on the tl are 1-2 inches shorter than tl are. Did u just cut 2 inches from the straight section and reweld it?
Old Dec 18, 2009 | 08:09 AM
p.diddy's Avatar
yea im pretty sure you just cut it from the straight section. im picking up a TL comptech b-pipe this weekend. im glad you asked this question because i was wondering myself about this.
Old Dec 18, 2009 | 03:35 PM
Chicago6MT's Avatar
whats the benefit of the b-pipe. CT site says there is none...
Old Dec 18, 2009 | 03:43 PM
p.diddy's Avatar
The competch b-pipe is bigger in diameter than the stock pipe so allows more air flow which benefits your exhaust. It's a plus if u have intake headers and exhaust and or high flow cat. Comptech doesn't make it anymore. U can only get used.
Old Dec 18, 2009 | 07:02 PM
RooEng's Avatar
There's a bend right after the cat so I cut mine about 4" from the cat flange. There's also a bend right after the resonator and the car has a heat shield right above it. It's a tight fit and if you don't cut the TL pipe, it'll hit the heat shield.
I put the TL pipe on with the mufflers and put the whole thing on the rubber hangers. Then I was able to hold the pipe up to the cat flange and measure how much to cut out.
I didn't notice any power gains but while I was cleaning it, I ended up polishing it. So the looks alone was worth it. I wouldn't do it just for power gains.
Old Dec 18, 2009 | 08:36 PM
p.diddy's Avatar
its not suppposed to be a power gainer. it better helps air flow for your exhaust system because of the larger diameter piping.
Old Dec 18, 2009 | 09:14 PM
friesm2000's Avatar
B A N N E D
which will help the power if you got other mods to make it neccessary, like an S/C
Old Dec 18, 2009 | 09:26 PM
Allout's Avatar
Blown is Best
Put mine in soon after SC.
Old Dec 18, 2009 | 09:33 PM
p.diddy's Avatar
lol thats what i mean. their thinking the pipe itself gains you power. it more so frees up power.
cant wait to put mine on that and my high flow cat. im ready for that hp increase.
Old Dec 18, 2009 | 09:38 PM
friesm2000's Avatar
B A N N E D
cant wait to put mine on.
but yeah for a otherwise stock motor (even with boltons), it will not do much, but if you are FI, strokin, or sprayin then yeah it will more then likely help you put more power down to the ground (freeing or producing the power )
i thought you already had it in
Old Dec 18, 2009 | 09:57 PM
p.diddy's Avatar
not yet. im was supposed to head up to new york tomorrow to get it but philly is getting 6 inches of snow tomorrow so when this snows melts some ill go get it. probably some time next week.
Old Dec 18, 2009 | 11:07 PM
Allout's Avatar
Blown is Best
Not sure if anyone has ever tested before and after but potentially, you could lose a bit of low end torque on an NA motor.
Old Jan 3, 2010 | 07:18 AM
p.diddy's Avatar
just got my b-pipe installed and it was a perfect fit didnt have to make any modifications.
Old Jan 12, 2010 | 04:15 PM
Lone Wolf
the one made for the tl?
Old Jan 12, 2010 | 04:19 PM
p.diddy's Avatar
Yea
Jul 16, 2017 07:33 AM
BoricuaTL
Apr 8, 2016 01:08 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
k6biv
Sep 22, 2015 02:06 PM
