comptech b-pipe
yea im pretty sure you just cut it from the straight section. im picking up a TL comptech b-pipe this weekend. im glad you asked this question because i was wondering myself about this.
The competch b-pipe is bigger in diameter than the stock pipe so allows more air flow which benefits your exhaust. It's a plus if u have intake headers and exhaust and or high flow cat. Comptech doesn't make it anymore. U can only get used.
There's a bend right after the cat so I cut mine about 4" from the cat flange. There's also a bend right after the resonator and the car has a heat shield right above it. It's a tight fit and if you don't cut the TL pipe, it'll hit the heat shield.
I put the TL pipe on with the mufflers and put the whole thing on the rubber hangers. Then I was able to hold the pipe up to the cat flange and measure how much to cut out.
I didn't notice any power gains but while I was cleaning it, I ended up polishing it. So the looks alone was worth it. I wouldn't do it just for power gains.
cant wait to put mine on that and my high flow cat. im ready for that hp increase.
not yet. im was supposed to head up to new york tomorrow to get it but philly is getting 6 inches of snow tomorrow so when this snows melts some ill go get it. probably some time next week.
Blown is Best
Not sure if anyone has ever tested before and after but potentially, you could lose a bit of low end torque on an NA motor.
BoricuaTL
04-08-2016 01:08 PM
