Codes Help
Old Jul 25, 2011 | 11:53 AM
PANAMARED's Avatar
Codes Help
Hello friends. I recently scanned my 01 5AT CL-S (100K miles) and got a bunch of codes. Lucky none of them came from the tranny! The scan tool here could only be operated in spanish so the description of codes is all weird. Can anyone help with these codes, been trying to get complete list describing error codes but no luck.
SRS
09-03 driver seat belt sensor (think previous owner disabeled it, which I actually like)
15-03: passenger position sensor?
ABS
25-1
64-1
83-1
93-1
97-1
65-2
I know one of them is the secondary oxygen sensor because it is missing sensor and cat converter; believe it is error #65-2. Almost sure another error(maybe 93-1) will be the TPS (Throtle Position Sensor) which I already bought and plan to replace soon (it malfunctions once in a while, I notice when shifting acts up).
Can anyone help with these codes? Is any of them critical for the vehicle operation (I donīt really care about the VSA, if it does not work is fine by me). All help is appreciated. All the best!
Old Jul 25, 2011 | 01:41 PM
civicdrivr's Avatar
65-2 is the secondary O2.
I cant seem to find anything else on the other codes.
Old Jul 25, 2011 | 01:53 PM
PANAMARED's Avatar
Thanks civic! really appreciate help. If anyone can comment with these codes, I will be really thankfull.
25-1 said in spanish something like "fail sensor ind desv?
64-1 fail sensor volt supply?
83-1 fail ECM relay?
97-1 fail motor sub-strang?
Thanks in advance!
Old Jul 25, 2011 | 02:00 PM
civicdrivr's Avatar
I was able to find some more info on this one:
83-1 - ECM/PCM Relation Failure; possibly a short somewhere in the wiring.
Cant find anything else on the others.
Old Jul 25, 2011 | 03:42 PM
PANAMARED's Avatar
Thanks again! will keep looking and all help is appreciated. Car runs great, fuel efficiency OK (considering its driven at +110 MPH almost every day), idles fine, recently did the full maintenance (change all belts,etc)... I'm not going to worry too much about those codes (will try to solve but won't lose any sleep over it) - All the best my friends!
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
