CODE 9-3 for SRS and CODE 1-6 ABS
Old Dec 9, 2010 | 09:31 PM
DURAN007's Avatar
Does anyone have the acura cl service manual that can look up SRS code 9-3 and ABA code 1-6? If you do can you share the pages or steps that is used to trouble shoot the codes. ThankS!
Old Dec 10, 2010 | 12:14 AM
dsickles's Avatar
9-3 is for a driver's side seat belt
1-2(RF), 1-4(LF), 1-6(RR), 1-8(LR): There is electrical noise in the wheel sensor or its connection.
google is your friend.
Old Dec 10, 2010 | 12:17 PM
DURAN007's Avatar
Is rr the driverside or passenger side?
Old Dec 4, 2011 | 08:53 PM
gearhead917's Avatar
i have a 97 cl 3.0 . SRS light on .tried resetting with jumpers but lite on as soon as the car starts. Zero info regarding troubleshhoting in my manual. Have heard could be multiple things triggering the light like seat belt switches etc. any help appreciated located said switches and troubleshooting strategy to get this fixed. thanks folks
Old Dec 4, 2011 | 09:23 PM
exl124's Avatar
Correct me if I am wrong, but I think the seatbelt issue has a lifetime warranty from the dealer and they will replace it for free. I could have sworn I heard this before...call up your local Acura dealer to double check...at least you can get that taken care of for free.
Old Dec 5, 2011 | 07:39 PM
aznboi2424's Avatar
Your posting in the wrong section. This is the 2G CL section, you drive a 1G CL.
This is true, so at least that should fix the SRS light.
Old Mar 6, 2012 | 08:15 PM
atlclgirl's Avatar
4th Gear
Just tried resetting my srs with the paper clip method found on youtube and here as well and if you followed the directions, it will reset yours srs unless there is a more serious issue going on that trigger your srs light.
Old Mar 14, 2012 | 05:48 AM
DURAN007's Avatar
One of your seatbelts buckles are out of wack. Change it and the 9-3 code will go away.
Jamus22
Jun 11, 2023 10:08 AM
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
