Clutches. Want a clutch that will hold power and drive nice?
Old 04-01-2009, 10:29 AM
  #81
Former Sponsor
MrHeeltoe's Avatar
We just hear stuff from time to time. One customer here has a car that is undrivable. It might be due to other issues but still I think there is room for more than one clutch option.
I don't see how a flywheel and a pulley would have issues with eachother. They are completely separate parts. Could you elaborate?
Old 04-01-2009, 11:50 AM
  #82
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,353 Likes on 4,915 Posts
I agree, having more then one option would be excellent. It may even lead to some competetiveness that could drive prices down
There were threads from awhile back about the CT clutch and underdrive pulleys not playing nicely with each other.
Old 04-01-2009, 12:26 PM
  #83
wut.
CG2PROJECT's Avatar
, I will elaborate... with a link.
http://www.acura-cl.com/forums/showt...=442841&page=2
You should look into it beforehand.. so nothing like that ever happens again and people telling you that their **** broke. (:
Old 04-01-2009, 04:12 PM
  #84
1hotcls6's Avatar
my CM kit is getting putting on this monday
Old 04-02-2009, 10:11 AM
  #85
civicdrivr's Avatar
Please, please, please keep us informed.
Old 04-02-2009, 10:26 AM
  #86
poisx7's Avatar
HOW MUCH $$$$
Old 04-02-2009, 01:00 PM
  #87
1hotcls6's Avatar
$1500 stage 4 w/ 6puck clutch
Old 04-02-2009, 03:50 PM
  #88
Former Sponsor
MrHeeltoe's Avatar
I'm not buying that dude....the effect of taking too much dampening off the crank might produce excess bearing wear (maybe drop 20-30% of life of a motor that with theoretically go forever if well maintained), but there is certainly no way in my mind this would cause damage to the clutch. It's a little absurd to be honest.
Marcus
Old 04-02-2009, 10:54 PM
  #89
civicdrivr's Avatar
Absurd or not, are you planning on running the stock pressure plate (please say no)?
Old 09-01-2009, 10:49 PM
  #90
cl8trr's Avatar
No issues ever with the ur pulleys and cm flywheel
Old 09-01-2009, 11:17 PM
  #91
I got the Shifts
phee's Avatar
^how many miles?.
Old 09-02-2009, 09:46 AM
  #92
Lives in Boost
CL-Future's Avatar
I would buy an aftermarket clutch kit today if I knew it would hold the power on a boosted CL.
Old 09-02-2009, 06:51 PM
  #93
Former Sponsor
MrHeeltoe's Avatar
We are actually getting some info on this kit very shortly that should allow us to push it forward again.
Old 09-02-2009, 07:10 PM
  #94
wham bam thank you ma'am
Rajca's Avatar
hmmm another option for me. but $1300? can get a stage 4 form CM for $1100. and i plan on pushing more than what was stated my mrhealtoe. we will wait and see. my clutch is slipping more and more under hard shifts.
Old 09-03-2009, 06:14 PM
  #95
Former Sponsor
MrHeeltoe's Avatar
More than 450-500 ft-lbs to the flywheel? What sort of monster are you building?
Old 09-03-2009, 07:16 PM
  #96
poisx7's Avatar
A REAL monster i guesssssssssssss.
prob 400whp +plus to the wheels but then that is more than enuff on a heavy FWD IMO.
back to the main topic *whtz new on this clutch setup ???? GB****
Old 09-03-2009, 09:37 PM
  #97
Rajca's Avatar
im going to the wheels. a minimum of 420whp and 360wtq. if i can id like to keep it at 450whp and 400wtq on the safe side.
Old 09-03-2009, 10:52 PM
  #98
I got the Shifts
phee's Avatar
i think what we need is a clutch disc. the actual disc is all thats poorly designed in our trannys.
a good ceramic disc will be cheap, increase shift grab, and prevent slipping and premature wear.
Old 09-03-2009, 11:53 PM
  #99
Former Sponsor
MrHeeltoe's Avatar
Yeah and it is harder to drive smooth as well...The self adjusting pressure plate used does not have enough clamping force from what I can tell.
Old 09-04-2009, 02:17 AM
  #100
civicdrivr's Avatar
^ Thats my beef as well. Ill take a firmer pedal if it gives me more clamping pressure. I actually like when the clutch requires some muscle.
Old 09-04-2009, 07:07 AM
  #101
StreetKA's Avatar
get an g35 manual so you will need a muscle
Old 09-04-2009, 10:27 PM
  #102
civicdrivr's Avatar
Huh?
Old 09-14-2009, 08:28 PM
  #103
03 Boosted CLS
cb717cls's Avatar
So has anyone figured out a good clutch setup to put in there car? i have a boosted cl and put a CM fx300 setup in it after about 3500 miles it is starting to slip. i dont know if i should go to the fx400 6 puck or is there something better that will last and hold up?
Old 09-14-2009, 08:36 PM
  #104
Rajca's Avatar
stage 4, 4 puck if u drive ur car hard
Old 09-14-2009, 10:21 PM
  #105
Former Sponsor
MrHeeltoe's Avatar
pucks drive like crap though! I am going to drop something soon I think...it won't be cheap but we will be able to take payments.
Old 09-15-2009, 02:36 AM
  #106
3.2VtecTL's Avatar
Arrow
im interested...my CL-S 6 clutch is acting up I feel..
whenever I rev toward redline, the clutch pedal gets very firm and its harder to shift into gear it seems...
a friend of mine told me that its the oem spring in the clutch that are bad, or possibly broken...??
My CL has around 160,000....I think its that time
subscribed
Old 09-15-2009, 07:16 PM
  #107
03 Boosted CLS
cb717cls's Avatar
clutch officially went out today need one asap. gonna have to take it apart asap to send in to CM this sucks
Old 09-15-2009, 07:42 PM
  #108
Rajca's Avatar
pucks will make engages harder but it will grab and hold the power.
Old 09-15-2009, 09:34 PM
  #109
Unregistered user
LIPPSTUH's Avatar
need a tester? =P
Old 09-15-2009, 10:36 PM
  #110
Blown is Best
Allout's Avatar
Originally Posted by LIPPSTUH
need a tester? =P
Do it! Once it's proven to work, others will follow
Old 09-22-2009, 01:33 PM
  #111
3.2VtecTL's Avatar
Arrow
subscribed
Assuming my clutch went out on me last night!!!
I'm able to put it in gear, however when I let off the clutch pedal I get a grinding noise, and I refused to drive it, called a tow truck immediately!!
I'm praying that it isn't the transmission!!!
I need this asap.....will make payments!!!!
Old 09-22-2009, 02:33 PM
  #112
civicdrivr's Avatar
My clutch was slipping like crazy today. Odd though since last night it was perfectly fine.
Old 09-22-2009, 06:15 PM
  #113
Former Sponsor
MrHeeltoe's Avatar
Originally Posted by lippstuh
need a tester? =p
yes i do.
Old 10-05-2009, 10:09 AM
  #114
03 Boosted CLS
cb717cls's Avatar
any word on the clutch situation yet almost got mine out have a few more steps to go then im gonna need a new one asap.
Old 10-10-2009, 08:58 AM
  #115
poisx7's Avatar
SO ANY new NEWSSSSSSSSSSSSSSSSS................. ???????
Old 10-10-2009, 11:43 AM
  #116
Former Sponsor
MrHeeltoe's Avatar
News is...things have been a tad slow ehre so we have not had it as a mahor prority.
Maybe if there was an interest list going...
Old 10-12-2009, 01:58 PM
  #117
poisx7's Avatar
but i really think this a great void to FILL and FEEL
Especially if the product really delievrs what it promises.
My guess is SB got to take the risk and invest in this and let us be the ones to recommend you.
a prototype , a test car and some R & D but i am sure no one wants to just poof out $1400. If this ever comes to light I am sure ppl will buy it
Old 10-13-2009, 10:46 AM
  #118
Former Sponsor
MrHeeltoe's Avatar
Yes you are right...just trying to find the right timing for us.
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
tonio
02-05-2019 05:43 PM
whitesoxsfan12
09-07-2015 04:07 PM
Quick Reply: Clutches. Want a clutch that will hold power and drive nice?
