cls cams
Old Dec 20, 2009 | 08:01 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
cls cams
Can cls cams be dropped into clp heads with no other mods like stand alone or piggy backs?
Can the normal clp ecu figure the changes by itself or would a auto cls ecu be a solution ?
Also our cams can be changed without removing the heads correct?
looking to grab a pair if this can be done someway,if not I guess I'll be saving for a EMB and harness next,since it will be needed anyway.
Anyone got cls cams in their clp ?
Questions questions, I got alot,I know.
Old Dec 20, 2009 | 08:43 AM
YeuEmMaiMai's Avatar
yes the cams are a direct drop in and the ECM will handle it just fine. It's just like adding headers.....
Old Dec 20, 2009 | 10:53 AM
friesm2000's Avatar
B A N N E D
the ecu should be able to handle the cam change, but if you want maxinum benifit, it needs to be tuned
Old Dec 20, 2009 | 12:32 PM
OperationDarkie's Avatar
Ultra Negro
I would get valve springs just to be safe, from what I was told the cl type s cams are somewhat aggressive.
Old Dec 20, 2009 | 05:55 PM
civicdrivr's Avatar
Id search around for the complete heads. Youre intake (?) valves arent the same size so Id wonder if running the CL-S cams would be an upgrade.
Old Dec 20, 2009 | 06:43 PM
Rajca's Avatar
wham bam thank you ma'am
the cl cams have larger lobes(sp?). so it will be a + in power but getting the whole head would be that much better. ill have 2 spare heads in a few months.
Old Dec 20, 2009 | 08:00 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
u cant just drop that shit in... u need to sweaking
Old Dec 20, 2009 | 08:04 PM
Rajca's Avatar
what?
Old Dec 20, 2009 | 08:06 PM
tweaking*
Old Dec 20, 2009 | 08:28 PM
^PM'n
I'm almost sure it will give gains cams alone.
And it would be beter to have the complete heads.
I would do some work to them.before they were installed
Old Dec 20, 2009 | 08:32 PM
Rajca's Avatar
deff get them pnped. dont know if u have done the 105k but also a good time to do that, new coolant, head gaskets and possibly upgrade the valve train.
Old Dec 20, 2009 | 11:02 PM
people use these cames on the J30a1/2 all the time with the stock valvetrain
CL-S progression 01
Jan 26, 2016 04:15 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
Papa Roe
Sep 26, 2015 11:45 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
