Climate Control Air Flow switch
Old Dec 22, 2002 | 09:40 PM
russianDude's Avatar
I just noticed when I try to change air flow mode to window & feet, it makes grinding noise.... all other modes are smooth....
Does anyone else have this noise when switching mode for air flow ? Its not loud, but sounds kinda abnormal ( only when I switch it to feet & window, all other modes sound normal ).
You will have to turn off your fans to listen...
Is that normal?
Old Dec 22, 2002 | 11:55 PM
runis's Avatar
A-CL Zen Buddha Master
As long as it only makes it when it is actually switching modes and not the entire time it is on that mode not too big of a deal...probably will just go away...mine did. If it is always on in that mode...it is abnormal.
Old Dec 23, 2002 | 09:38 AM
Yeah, the noise is only present during actual swtiching, when the switching is done the noise is gone.. I hope its normal. The only reason I noticed is because all other modes make no noise, only switching to feet and window makes this noise...
Did you have the same issue?
Dec 7, 2020 05:39 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Sep 17, 2015 10:16 AM
PortlandRL
Sep 14, 2015 12:01 PM
