Climate Control Air Flow switch
I just noticed when I try to change air flow mode to window & feet, it makes grinding noise.... all other modes are smooth....
Does anyone else have this noise when switching mode for air flow ? Its not loud, but sounds kinda abnormal ( only when I switch it to feet & window, all other modes sound normal ).
You will have to turn off your fans to listen...
Is that normal?
Is that normal?
As long as it only makes it when it is actually switching modes and not the entire time it is on that mode not too big of a deal...probably will just go away...mine did. If it is always on in that mode...it is abnormal.
Did you have the same issue?
