"click" sound when shifting!
Old Mar 9, 2011 | 01:34 PM
StealthBomber8's Avatar
Exclamation "click" sound when shifting!
I have been hearing a clicking sound whenever i shift gears right when i release the clutch from engagement point. Please help!
Old Mar 9, 2011 | 01:36 PM
civicdrivr's Avatar
More info?
Old Mar 9, 2011 | 01:45 PM
actually its more like someone sucking their teeth sound
Old Mar 9, 2011 | 01:56 PM
um just drove it.. but ill press the clutch in then put it into the next gear then release the clutch and as soon as it disengages ill hear the sound like someone is sucking their teeth. Another problem is that whenever i come to a stop sign and want to take a 90 degree turn in either direction ill hear this constant clicking sound at hard angles while turning then as soon as i start to starighten it out its stops making the sound
Old Mar 9, 2011 | 03:13 PM
fuzzy02CLS's Avatar
Say good by to your axles....
Mine are going too. No $ to replace them.
civicdrivr's Avatar
The clicking while turning is most likely your cv joints. Replace the axles and it should go away.
The only thing I can think of with the other noise is the hydraulic system for the clutch. Check the clutch fluid reservoir and make sure its filled properly.
Old Mar 9, 2011 | 03:40 PM
Well good thing i bought the extended protection plan. Thanks.
Old Mar 9, 2011 | 04:54 PM
StreetKA's Avatar
i have simillar sound i think, im waiting for my engine mounts to make sure its not that but then i think axles are next on the list.
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
kixo
Sep 25, 2015 03:07 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
