"click" sound when shifting!
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I have been hearing a clicking sound whenever i shift gears right when i release the clutch from engagement point. Please help!
Whats up with RDX owners?
More info?
um just drove it.. but ill press the clutch in then put it into the next gear then release the clutch and as soon as it disengages ill hear the sound like someone is sucking their teeth. Another problem is that whenever i come to a stop sign and want to take a 90 degree turn in either direction ill hear this constant clicking sound at hard angles while turning then as soon as i start to starighten it out its stops making the sound
The clicking while turning is most likely your cv joints. Replace the axles and it should go away.
The only thing I can think of with the other noise is the hydraulic system for the clutch. Check the clutch fluid reservoir and make sure its filled properly.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
kixo
09-25-2015 03:07 PM
