CL-S6 on a Minor Diet
#121
so far ive been able to take out 112+/-lbs and still need to weight the rear seats, and passenger seat, along with the rear braces behind the back seat.
with my math and scale, my car weights in at 3334+/- a few. will weight rear seat tomorrow and subtract.
now i also added weight, 77lbs, vis hood and nitrous system. if i take out a bottle that will reduce the weight by 24-25lbs. but i wont.
so 3441lbs +/-. doesnt seem like i have taken out alot. once i remove the rims it should be alot lighter.
and i have lost 14lbs, my contribute.
#127
I got the Shifts
remove all lining from your trunk.
lift up the rug in your car and take out the foam under it.
remove the foam under your hood.
lose the engine cover(s)
remove your door panels and take our the foam under them.
remove any junk from your trunk (clothes, trash, papers)
remove your owners manual.
remove your spare,jack, tire iron (not recommended)
replace big box subs with shallow mount 8 inch sub in stock position.(i have no sub)
remove your cat shield
get and CAI (but dont floor it to hear the sound)
replace your exhaust with aluminum piping (beware of rust)
mount some 16 inch wheels or lightweight wheels (less than 18lbs a rim)
increase tire inflation
only run half a gas tank at all times
replace valve stem caps with plastic caps
replace OEM lugs with light weight lugs
replace heavy OEM rotors with lighter ones (drilled slotted)
remove diffusor from your headlights
get smaller, lighter mufflers
get a lighter rear sway bar
lighter strut tower bar
Some coilovers and lighter than OEM strut and springs(k sport)
get a light weight radiator
port and polish your intake, throttle body
get headers
get a pulley
carbon fiber hood
carbon fiber trunk
remove spoiler or replace with CF one
remove lip kit
More extreme:
remove your glove box
lose the backseat if you dont have kids.
replace all glass with plexi
remove airbags
strip interior
scrape off all rust proofing from under your car
get a 6 speed swap (tranny is lighter)
get forged pistons
knife edge your crank
light weight flywheel with your 6 speed
lose weight yourself
remove moon-roof and replace with carbon fiber
#128
found it here https://acurazine.com/forums/showthread.php?t=716651
remove all lining from your trunk. done
lift up the rug in your car and take out the foam under it.doing during winter
remove the foam under your hood.done
lose the engine cover(s)when i race i take them off
remove your door panels and take our the foam under them.what foam?
remove any junk from your trunk (clothes, trash, papers)always empty
remove your owners manual.done
remove your spare,jack, tire iron (not recommended)done
replace big box subs with shallow mount 8 inch sub in stock position.(i have no sub) i have no raido/speakers
remove your cat shielddone
get and CAI (but dont floor it to hear the sound)custom
replace your exhaust with aluminum piping (beware of rust)will do but 3"
mount some 16 inch wheels or lightweight wheels (less than 18lbs a rim)on the hunt for 15lbs 17" rims
increase tire inflationalways is up, no when racing
only run half a gas tank at all timesonly when racing
replace valve stem caps with plastic capsthis is going too far, done
replace OEM lugs with light weight lugswhen i get rims
replace heavy OEM rotors with lighter ones (drilled slotted)done
remove diffusor from your headlightsexplane
get smaller, lighter mufflersdone
get a lighter rear sway barnot sacrificing handaling
lighter strut tower barnot sacrificing handaling
Some coilovers and lighter than OEM strut and springs(k sport)done
get a light weight radiatorits on the list
port and polish your intake, throttle bodysomeday
get headersgot custom
get a pulleydone
carbon fiber hooddone
carbon fiber trunkon the list
remove spoiler or replace with CF onedont have one
remove lip kitdont have one
More extreme:
remove your glove boxpass
lose the backseat if you dont have kids.done
replace all glass with plexitoo much for me
remove airbagsone day
strip interior80% done
scrape off all rust proofing from under your carnot smart
get a 6 speed swap (tranny is lighter)got it![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
get forged pistonsone day
knife edge your crankone day
light weight flywheel with your 6 speedin a month or so
lose weight yourselfalready did
remove moon-roof and replace with carbon fiberon the list
get a pulleydone
More extreme:
InFaMouSLink
10-30-2015 09:43 AM
