CL-S Valvetrain clatter.....
My CL-S has had a pretty audible valvetrain clatter at idle for some time now. It's got 21k on it and I'm running Mobil 1 5W-30 oil. What weight oil would you recommend to reduce the noise? Thanks.
-Jon
-Jon
have you asked the dealer to look at it?
i use mobil one as well. i don't think it should cause more valvetrain noise.
since you are under warranty there's no reason not to let the dealer check it out.
Cost Drivers!!!!
Originally Posted by anothercls
Can someone explain what the noise is supposed to sound like? I might have this problem, but not exactly sure....
tapping noise in your engine and it sounds like there is chatter.
I worry because my engine used to bog hard before i had the timing belt replaced. Bad timiing belt could easily f with the valves
RSpyder
09-30-2015 12:46 AM
