CL-S Cold air intake ?
I'm looking into getting a cold air intake but K&N doesnt seem to make one so I was thinking about the Injen intake but I have a few questions if anyone knows about it it would be a big help. I was wondering where the air filter sits. If it hangs under the car or not because my buddy I use to work with had a slammed Integra and everytime it rained he had to disconect it & put a ram air on because the cold air hung below the car and would suck up water if he drove through a big puddle and my X had a 02 celica w/ a cold air intake & factory suspension & wheels & one day she drove through a big puddle & it sucked up a ton of water & blew the motor. So if anyone knows where the air filter sits it would be greatly appreciated.
A cold air intake would have the filter below your driver's side headlight. Its behind the splashguard, but not enough to prevent water from getting in. I'm going to be converting my CAI into a short ram variation to prevent problems. (Each style has its pro's and con's of course.) But I think for around $50 you can get a hydro-lock one way valve (don't quote me on its exact name) that sandwiches in between your intake tube to prevent water from getting in.
Unless you submerge your filter under water i wouldnt worry about it. Puddles splashing up wont harm it or cause your motor to blow up. I traveled in what was near a thunderstorm with heavy rain for almost 20 hrs on a trip to florida. Every stop for gas the filter was dry
Also.. see vid. Filter bone dry afterwards
http://www.youtube.com/watch?v=wvqc6wcng_g
I also agree that unless you submerge the front end, you won't have a problem. If you are still concerned they do make a unit, hydro-lock type, that will keep water out with no issue. It is alot better using a cold air over the ram air, especially because these engines get very warm, and the colder the air, the better the performance. Injen or AEM are both very good units. On my 2003 CLS, my filter sits right behind the driver side driving light.
unless you submerge your filter under water i wouldnt worry about it. Puddles splashing up wont harm it or cause your motor to blow up. I traveled in what was near a thunderstorm with heavy rain for almost 20 hrs on a trip to florida. Every stop for gas the filter was dry
also.. See vid. Filter bone dry afterwards
Agreed that your car more than likely won't hydrolock unless the intake is submerged. And yeah the filter sits right behind the driver's side headlight, pretty much protected by a bunch of splash guards. Of course water can get in, but more than likely not enough to do damage. You can get additions to your intake if you go with either Injen or AEM, which aim to help prevent hydrolock. AEM has a bypass valve and Injen has a pre-filter you slip on over the filter like a glove.
Like I say in almost all the CAI threads, I called the guys at Injen and asked them how much water their Hydroshield blocks. The guy said "it'll protect you against hydrolock, as long as the filter isn't completely submerged"
but honestly, if I could go back, I probably would have gotten a Comptech Icebox instead, since I live in Oregon..
I wouldn't recommend getting an AEM unless it's the V2. I believe the V2 has that rubber bushing to mount the pipe between the fender wall. The other AEM intake doesn't, and I've seen about a half dozen people on this forum post pics of their cracked and split AEM intake pipes.
rcs86
08-02-2016 06:52 PM
