Cl keep cuting off.
Old Nov 7, 2006 | 12:38 PM
Ellicit's Avatar
Cl keep cuting off.
Let's say I drove the car for almost 3+ hrs and I turn it off. When restart it back up the car acts funny... like its about to shut off on me the engine shakes and then when I press the gas hard it gets normal... the other night I was driving home doing about 60 on the express way the car shut off on me and the green key sign came on the dash broad. I pulled over and started it back up... happen about 3-4 time
What could it be?
Old Nov 7, 2006 | 12:46 PM
AcUrAge703's Avatar
Check your timing belt....i had that happen to me with my old car...timing belt needed to be replaced....check it soon cuz you dont want to pay for bent valves...if it snaps....that or your alternator/starter.....
check by starting your car and then just get out and see if it stays on...if it does...then your battery might be messed up or something else weird....
if not then your alternator/starter is bad and needs to be replaced...
Old Nov 7, 2006 | 12:48 PM
aznxtallxboy's Avatar
what he said
Old Nov 7, 2006 | 12:50 PM
Ellicit's Avatar
The water pump and the timing belt was replace by the DEALER... could it be an idle sensor? and the shaking never happens when the car is cold
Old Nov 7, 2006 | 12:54 PM
RaviNJCLs's Avatar
How long was it replaced? Check your plugs and air filter too.
Old Nov 7, 2006 | 01:13 PM
Ellicit's Avatar
about 7000 miles ago...
Old Nov 7, 2006 | 01:17 PM
RaviNJCLs's Avatar
And the problem started when?
Old Nov 7, 2006 | 01:27 PM
Ellicit's Avatar
well, the shaking has happen before the timing belt change... it would cut off but not as much as it did yesterday...
I have also changed the plugs
I never changed the filter or the wires yet
Old Nov 7, 2006 | 01:32 PM
RaviNJCLs's Avatar
Never changed the air filter? How long have you had the car? Take a look at it. I would think that the dealership would have pointed it out to you though. If it looks clean, take the car back to the dealer and have them check it.
Old Nov 7, 2006 | 01:34 PM
Ellicit's Avatar
oh man I'm in the wrong forum........ this is a 1st gen.
Old Nov 7, 2006 | 01:39 PM
vibe's Avatar
so thats a total of 3 "cl keep cuting off" threads from this guy
Old Nov 7, 2006 | 01:41 PM
Old Nov 7, 2006 | 01:46 PM
Ellicit's Avatar
no ass its only 2... some 1 cAN delete this one pls
eastcoastguy
Oct 29, 2015 03:00 PM
kev87a
Oct 18, 2015 02:03 AM
polish_pat
Sep 30, 2015 12:22 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
prbori
Sep 27, 2015 01:37 AM
