Check Engine WTF???
Old May 25, 2002 | 01:31 PM
liquid_x's Avatar
Check Engine WTF???
ok so i got my system installed yesterday and last nite i was putting back the back seats and i was working with the radio on but the car wasnt on now i know your not supposed to do that with a system but i was like w/e i was workin on the car for about an hour or so then pulled the car back into the garage this morning im gonna go fill the car up with gas and the battery is dead so i jump it then i notice the check engine light is on and i was like wtf what the hell is that on for? whats the problem here cause it wasnt on yesterday or last nite it jus came on this morning i need input cause i dunno what the hell caused this
Old May 25, 2002 | 03:09 PM
Dom418's Avatar
I LOVE MY CAR
How many miles do you have???
are you sure it's coming on to let you know it's time for your scheduled maint. 7,500, 15,000, etc......??
DOM
Old May 25, 2002 | 05:40 PM
KavexTrax's Avatar
You jumped the car right? Maybe the computer goes nuts and issues some error codes, have the dealer check it out.
Old May 25, 2002 | 11:15 PM
liquid_x's Avatar
cant be mileage i only have like 5100 miles but i think kavex's idea sounds logical
i think service is closed on monday so tues i'll go to the dealer
Old May 26, 2002 | 12:17 AM
SinnedTL's Avatar
Ain't No Other...
i remember streeteffectz said that it was normal for the light to come on after you take out the seats because of the srs airbags on the side of the seats....you gotta go to the dealer and tell them that the light came on and act like you dont know nothing about it, then they will just turn it off for you...
Old May 26, 2002 | 01:21 AM
Dom418's Avatar
I LOVE MY CAR
To the best of my knowledge, there's no airbags connected to the BACK seats...
Maybe TL's are different....:P
DOM
Old May 26, 2002 | 02:27 AM
SilverKnight's Avatar
Retired. Not available.
If it's just an error code, remove the negative wire at the battery, leave it out for a while then put it back in. You will need your radio code.
Old May 26, 2002 | 11:40 AM
liquid_x's Avatar
error code??? nuthin is wrong with the radio the check engine light is just on but yea there are no airbags in the back seats
Old May 26, 2002 | 12:09 PM
gmilian's Avatar
Red X
when i got my nav conversion done, the check engine light was on. i just disconnected the neg. wire to the battery for ten minutes and it was fine. just be sure to re-set your memory seats and radio stations.
Old May 26, 2002 | 12:19 PM
Nitin's Avatar
But I just got here
Speaking of which, I just had a huge problem with this exact same SRS light situation. I got an inverter installed underneath the front passenger seat but when the seat was put back into place, the SRS light came on. So I took it to the dealer and they told me the passenger side airbag system had been fried because of the power source underneath the seat. They told me it'd be about $1200 to repair everything and said it was not under warranty because of the work that had been done. As I was driving away, I noticed that the SRS light never came back on again. Anyways, I took it to another Acura dealer and they ran the diagnostics and said everything was perfectly fine.
Old May 27, 2002 | 07:21 PM
liquid_x's Avatar
ok so check it out the battery is dead when the power line for the system is connected to the battery but when i took the power to the system out the battery worked perfectly fine my dad thinks something must have shorted out could it be that the bar in the trunk touching the magnet of my 6x9 be causing this problem?
Old May 27, 2002 | 07:30 PM
momentum3.2's Avatar
War Eagle!!!
eh...no...how many damn 1000 watt amps have you got going to that battery?
just hold on to the "Select" + "Reset" buttons til the engine light goes off if you're lazy
You've got a short but it's not because of the tension bar touching your 6x9. Have you got a secure ground? If you grounded your system in the trunk on one of the bolts on that silver cylinder lid, I'd remove it and ground somewhere else. That silver disc-looking thing is the PCM cover. You do not want to ground that puppy out.
btw, if you disconnect your batter, you'll need your radio code because the head unit will forget where it is (meaning, it will think that it's been stolen because the low-voltage current that keeps the memory and where your cd last stopped (that also knows when your CL was built) has been disconnected.)
Old May 27, 2002 | 07:33 PM
liquid_x's Avatar
by the way i forgot to mention that when the power source to the system is not connected to the battery the check engine light is gone
im gonna go back to the place i got it installed at and complain like a muthaf**ka
Old May 28, 2002 | 12:43 AM
dude, I talked about the error code stored in the ECU, not the radio code Try to disconnect the battery for a while then plug it back in. Maybe you'd save yourself a trip to the stereo shop or the dealer.
Old May 28, 2002 | 12:46 AM
Ummm .... I think that is how you reset the "maintainance required" light, not "check engine" light.
Old May 28, 2002 | 07:58 AM
War Eagle!!!
oh yeah...whoops....It's all the same, man! It's all the same!!! :P
Old May 28, 2002 | 08:26 AM
SiGGy's Avatar
Moderator Alumnus
Re: Check Engine WTF???
It's always a good idea to fully charge the battery before using if it's heavily discharged. As you put an enormous strain on the electrical system (alternator/voltage regulator) for the next few days/weeks.
To recharge the battery fully with your alternator from the current state it sounds yours was in, you would have to drive 5+ hours down the highway without stopping.
If it is an emergency, then do it. Otherwise it's always a good idea to recharge with a charger if possible....
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Billu99tl
Sep 13, 2015 11:30 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
