Check engine light flashing
I now drive an accord....
On my way to work this morning I pull out of parking lot and give it a little too much gas on the wet roads and experince a little wheel hop. The next thing I know the CEL is flashing and continues for about 1 minute then goes off. I drove about 5 more miles to work and with the car running perfectly fine. Doesn't the CEL usually come one and stay on? I have never had a CEL flash at me before. When I get a chance I will stop by autozone and have them pull the code. Anyone think I should bother going to the dealer yet?
Originally Posted by anothercls
Does Autozone charge for this service?
Can anyone tell me where the obdII port is?
doesnt matter if the CEL didnt throw a hard code...as in the check engine light stayed on solid there will be nothing to read....sounds like temp random misfire
Originally Posted by spdy0001
I don't think so
If you look under the "not an ashtray" container, there is an "L" shaped piece of plastic that can be removed. Feel around the top, it pulls right out. The ODBII port is behind that.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Are you saying that there will only be a code if the light stays solid? and if it just flashes for a minute that there would be no code, like in my situation?
You actually seconded my opinion of the misfire.
Originally Posted by RaviNJCLs
I think it's free.
i thought for six speeders the obd-ii port is located somewhere else? Like right under the driver side dash.
HeloDown
09-08-2015 06:51 PM
