Check engine light.........
help my CEL just when on and i need to know wats causing it, i was looking up info on where is the port that we need to short to get the light flashing but no one talks about it, can someone direct me to the port that needs to be short(not under the coin tray but another port) thanks
btw if you have the read out does anyone have the look up chart for each flash mean too? like if i get a code 22 wat does that mean? or if someone can check is the one i have here works for a tl-s?
Trouble Code
0 Faulty ECM
1 Left HO2 Sensor
2 Right HO2 Sensor
3 Manifold Absolute Pressure (MAP)
4 Crankshaft Position Sensor (CKP)
5 Same as 3
6 Coolant Temp
7 Throttle Position Sensor (TPS)
9 No. 1 Cylinder Position (CYP)
10 Intake Air Temperature (IAT) Sensor
12 Exhaust Gas Recirculation (EGR)
13 Barometric Pressure
14 Idle Air Control (IAC) valve
15 Ignition output signal
16 Fuel injector
17 Vehicle Speed sensor (VSS)
18 Ignition timing adjuster
23 Left knock sensor
35 Traction control system
36 Same as 35
41 Left Oxygen sensor heater
42 Right Oxygen sensor heater
43 Left fuel supply system
44 Right fuel supply system
45 Left fuel metering
46 Right fuel metering
53 Right knock sensor
54 Crankshaft position 2 (CKP sensor)
59 Cylinder position 2 (CYL or CYP sensor)
thanks
jon
Trouble Code
0 Faulty ECM
1 Left HO2 Sensor
2 Right HO2 Sensor
5 Same as 3
6 Coolant Temp
16 Fuel injector
36 Same as 35
thanks
jon
its a 03 tl-s i went out a bought a obd scan tool, hopefully this will help, i sets the light today and it came back on like almost right away...the only mod i have that i think might have caused it is the header but i had it installed for liek 2 weeks already with out any problem anyone have any idea wat this might be?
thanks
JON
thanks
JON
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
