A Cheaper Way to Trick VTEC
Old Dec 7, 2002 | 01:31 PM
Juker008's Avatar
TRELOS
I heard of a cheaper way to trick VTEC into engaging at preset points, rather than purchasing a aftermarket VTEC controler.
The way that I heard it (thrown at me) was to intall an MSD RPM activated control box, intalled inline with the actuator. U can then plug in different control modules that are set at different RPM settings to control VTEC engagement.
Anyone heard of such a way of doing this? Possible. Sounds right.
Juker008
Old Dec 7, 2002 | 01:45 PM
Rescuer's Avatar
Evil Bob Knieval
but at what RPM would you set it to?
how would you determine that?
Old Dec 7, 2002 | 02:37 PM
sidemarker's Avatar
try cruising at about 50 mph turn off the car: one click back then wait a second then put it back into normal position but dont start it. floor it and see what happens...
this may sound weird but this was a neat trick for the 6 gen v6 accord. because vtec kicked in at about 3000 rpm if you do the method above then vtec would kick in at about 5000 rpms which felt pretty cool...
i just know im going to get flamed for this....
sidemarker
Old Dec 7, 2002 | 02:46 PM
AFitchTLS's Avatar
:flamer:
Old Dec 7, 2002 | 04:45 PM
Juker008's Avatar
TRELOS
By changing out the RPM modules. They look kinda like fuses that plug into the control module. These RPM modules have preset RPM intervals printed on them. So u could have VTEC ingage at any preset RPM that u want.
Juker008
Old Dec 7, 2002 | 04:46 PM
Juker008's Avatar
TRELOS
sidemarker
I don't get it.
Juker008
Old Dec 7, 2002 | 05:02 PM
Pappy's Avatar
Do it! U Only Live Once!
I don't know Juker...you're spending too much time in the sun. Just kidding...I think.
Old Dec 7, 2002 | 05:13 PM
scalbert's Avatar
That would work to turn it on but you might also set a DTC as the ECU monitors the VTEC pressure switch. If this comes on too early the ECU would think the solenoid failed and set a code. But that could be easily handled with another switch.
The main problem is in the fuel supply and ignition timing. The high lobe zone (in VTEC) has different fuel and timing maps specifically for that lift and duration. If you activate it before the factory point the ECU will still be supply fuel and firing the plugs as if it were on the low lobes. Little to no power would be gained and could loose power.
The VAFC allows you to tune the fuel supply for this change.
Old Dec 7, 2002 | 05:49 PM
Juker008's Avatar
TRELOS
Scalbert,
Ok so there is no better, cheaper, alternative than to use an VAFC.
Pappy,
I decided that it is pointless to spray medical into my car. better to spray into my mouth .
Juker008
Old Dec 7, 2002 | 06:15 PM
Rescuer's Avatar
Evil Bob Knieval
Juker008
i know how to use the control module
i was asking "how you would go about determining WHAT RPM to set it at"
Old Dec 7, 2002 | 09:45 PM
JasonT's Avatar
I think sidemarker means to do that procedure while driving? Correct?
Old Dec 7, 2002 | 10:07 PM
sidemarker's Avatar
correct
sidemarker
IBankMouse
Jun 13, 2020 12:53 PM
mlody
Dec 4, 2019 02:11 PM
brboy
Oct 5, 2015 11:34 AM
Mr.Tea
Oct 2, 2015 10:32 PM
STL TL-S
Sep 23, 2015 08:52 PM
