cheap light weight battery!!!
i was at work today and i walked past a cart full of what looked like small car batteries ...i picked one up and i was like damn thats light...290 CCA 12v and about 10lbs or less for 20$ ...these are tractor lawn tractor batteries...wonder if the 290's enough...maybe just for track day ?
Spectacular Aroma About
Re: cheap light weight battery!!!
optima weighs close to stock.
for $20, you should get one and try it TypeR.
Lead Footed
The biggie is going to be when it is hot . . . that's when I had most of my problems getting a car to fire . . . of course I was running 11.25 to 1 compression . . :P
I'd bet you could find smaller batteries that are in the 350-400CCA range and still weight a lot less.![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
Ruf
Ruf
Sweet as Gold
Originally posted by kHmER Co
cant you just start the car, then take the battery out, like manual cars?
mister D
Originally posted by Ant7701
You can do that w/ just about any car...auto or manual...but whats the point??
Moderator Alumnus
your battery is also engineered to act as a capacitor. You would allow all of your electronics be wide open to a voltage spike. I.E. cooling fan turning on and off would produce a spike.... pressing the brake pedal...
Enough of a spike and you coulf fry your ECU.
You could replace the battery with a large capacitor once the car is running. Which would be lighter...
Although mot newer electronics are pretty good handling voltage spikes I wouldn't play with fire...
mada51589
05-03-2022 08:54 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
