Changing my fogs to PIAA super whites
I need FI
I searched the forum and I can't seem to get good instructions on how to change the fog light bulbs...
Any suggestions?
Any suggestions?
Not Asian
There is a screw that you can access from the inside of the grill. Use a long phillips screw driver to reach it. Unscrew it and then you should be able to pop out the housing. The PIAA bulbs are a tight fit. I actually had to dremel a little bit of the plastic to squeeze mine in there. Also, remember not to touch the bulbs with your bare hands.
Be Strong AND Courageous!
This is the best site I have seen so far for repalcing the road lamps....great pics...looks like about a 1/2 hour job....I am about to replace mine...one of the OEM bulbs burned out at 41k miles...hope you get yours in without problems....
Check this thread for details on replacing the bulbs
http://wizardsworks.org/chod/acura/m6/
It took me 5 min, all u do is jack up both sides of ur car. Reach through the plastic and push out a little tab.(on the left side of car it is on the right side of lamp, Reverse for right side) The whole lamp should pop out and u can reach it from the outside. Turn the wires counterclockwise and switch bulbs. It only takes min after i figured that out. Read the owners manual if u get confused, it is in there. Good luck!
I need FI
thanks. I got it working. I changed them. I'll post picks if you guys want. However, I thought the color would of been a little more white. It's a little too blue for me. Anyways, it's mush better than the stock fogs, that's for sure.
Anyone here put anything else as bulbs that make it look nice?
'08 TL-S
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
sockr1
10-01-2015 01:31 AM
oyayjoe
09-12-2015 04:40 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
