Center Console Rattle
Old Jun 4, 2008 | 07:18 AM
DelawareCLS's Avatar
Searched, but didn't find anything which seemed to match what I am experiencing...
I've been getting a "rattle" coming from the center console which I think is being caused by the brushed silver trim rubbing the darker plastic of the base of the console, near where your right knee would be. I put "rattle" in quotes because it's not your typical rattle - the best way to describe it is that is sounds very much like the sound a Geiger counter makes...like a rapid staticky ticking sound. It occurs hot or cold, and can sometimes be temporarily (i.e. 3 minutes) remedied by applying pressure to the silver/plastic contact points, or by banging on the opposite (passenger) side of the center console.
My questions:
1) Anyone else getting this same sound? It's incredibly annoying.
2) Remedies that I haven't thought of? The more permanent the better. I'm thinking of pulling off the silver trim and running some electricians tape between the joint, replacing the trim and then cleaning up whatever's visible.
3) Any idea how to take the silver trim off the side of the console?? Didn't see any clear way to rmove it without breaking it.
Thanks.
Old Jun 4, 2008 | 11:51 AM
Corrosion's Avatar
White as night.
Hmm.. I'm sure I've read your exact problem before. I'll try searching for you.
AFAIK, the person took apart their trim and center console and found the culprit.
Old Jun 4, 2008 | 05:04 PM
orrin_b's Avatar
9th Gear
I had that same problem. It's coming from the part that the shifter goes through (don't know the name). It's a small plactic part that hooks onto the larger one. Mine was a bit loose so i took it apart and used electrical rubber tape as a washer to snug it up. It's been quiet for over a month now.
Old Jun 4, 2008 | 05:28 PM
orrin_b's Avatar
9th Gear
I had that same problem. It's coming from the part that the shifter goes through (don't know the name), not the silver trim. It's a small plactic part that hooks onto the larger one. Mine was a bit loose so i took it apart and used electrical rubber tape as a washer to snug it up. It's been quiet for over a month now.
The sliver trim is easy to remove. Remove the shift knob by turning it anti-clockwise...it can be hard at first. Next, pop out the black trim from around the silver one...it's snapped in. Then you'll see the clips for the silver trim, i used a tweaking screwdriver to unhook them.
Old Jun 4, 2008 | 05:50 PM
TypeStylinOnU's Avatar
dont be mad
Originally Posted by CLINTH
YOU CAN REMEDY YOUR RATTLE BY REMOVING YOUR CONSOLE TRIM AND APPLY FELT TAPE (EPT TAPE) WE CALL IT AT ACURA AND REINSTALLING THIS WILL ACT AS A BUFFER FROM THE 2 PARTS RUBBING/CONTCTING EACH OTHER
why are you yelling at us?
Old Jun 4, 2008 | 05:53 PM
ljmushock's Avatar
BECAUSE!!! Acuras are really nice! lol
Old Jun 4, 2008 | 06:17 PM
dont be mad
roflcopter!
Old Jun 4, 2008 | 09:09 PM
Thanks - I'll check this first. So, to take it apart, turn off the knob, then pop the boot off to get at the silver "shift gate"? I have a 6 spd if it matters.
Old Jun 4, 2008 | 09:12 PM
All I'd really need to know is how to get that silver trim off. Looks like it snaps on, but knowing me I am guaranteed to break some clips getting it off and then I am screwed. I'm happy to improvise anything that'll sit between those that contact point to eliminate the rubbing sound!
Is there a release clip anywhere to get the trim started coming off? Are there recesses I need to skip a thin flathead screwdriver into??
Thanks.
Old Jun 4, 2008 | 09:40 PM
orrin_b's Avatar
9th Gear
mine is auto and i'm not familiar with the 6 speed. sorry.
Old Jun 5, 2008 | 07:25 AM
fsttyms1's Avatar
Thanks.
Open the center console and lift up and back on the trim (starting from the end under the console lid)
Old Jun 5, 2008 | 07:28 AM
fsttyms1's Avatar
If your talking the silver piece that the boot attaches to, push down on the boot where it attaches to the shift knob, unscrew the knob. Then from the front (towards 136) lift up on the silver trim there and slide forward to release the rear.
Old Jun 5, 2008 | 07:48 AM
Ron A's Avatar
Administrator
Originally Posted by FINDLAYACURA
YOU CAN REMEDY YOUR RATTLE BY REMOVING YOUR CONSOLE TRIM AND APPLY FELT TAPE (EPT TAPE) WE CALL IT AT ACURA AND REINSTALLING THIS WILL ACT AS A BUFFER FROM THE 2 PARTS RUBBING/CONTCTING EACH OTHER IF YOU NEED ASSISTANCE OR WANT TO ORDER THIS TAPE LET ME KNOW.
CHOWELL@FINDLAYAUTO.COM
CLINT HOWELL
PARTS MANAGER FINDLAY ACURA
702-982-4160
CLINT HOWELL
Old Jun 5, 2008 | 12:41 PM
Sounds like that's the one - thanks. I'm betting it's the trim along the side of the console that's causing my problem, though
mlody
Dec 4, 2019 02:11 PM
vpasla1
Sep 17, 2016 07:24 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
