CEL Flashing during ON position
Old Dec 9, 2007 | 10:38 PM
CL FWD SPEED's Avatar
What to do, what to think
Found out today when I started my CLS6. I turned the car on the ON Position (before engine startup) and for about 10 sec. my CEL started to flash about 5 times and then it turns off. huh? I don't have the CEL on but it always happens when its on the ON position. The car drives good but I think my IAC valve is acting up again never changed it but I clean it before. 5 flashes could mean something? I have about 55kmiles and I"m S/C. before I had a code P1701 running lean and I got my valves adjusted and CEL went away. no more ticking. I tried to search but I couldn't find anything. anybody with a helms manual? car starts up fine, my a/f ratio is about 11.3 at WOT. runs great. is my motor shot????
Old Dec 9, 2007 | 10:52 PM
srehmat02's Avatar
I was under the impression that it was normal for it to flash with the key in the ON position.. or else my car is screwed too and my car runs super rich.
Old Dec 9, 2007 | 11:10 PM
is it normal? I thought it would just turn off instead of flashing? hmmm....well my CL-S is hibernating for the winter. I start her up from time to time. can anyone check to see if the CEL is flashing in your rides?
Old Dec 9, 2007 | 11:26 PM
srehmat02's Avatar
You've got me curious now, I will ask my buddy with an auto CL-S
Old Dec 10, 2007 | 10:46 PM
anyone?
Old Dec 11, 2007 | 11:55 PM
CLean 3.0's Avatar
CLeanest in its CLass
totally normal all cars do it Acuras, Nissans they flash because the computer is doing a self diagnosis on itself. im not sure on acuras but on nissans (im a nissan tech) you only worry when the light stays lit cause then theres a problem. so you shouldnt worry about a blinky light (unless its blinking while driving then theres some serious damage going on)
Old Dec 12, 2007 | 12:21 AM
[QUOTE=CLean 3.0]totally normal all cars do it Acuras, Nissans they flash because the computer is doing a self diagnosis on itself. im not sure on acuras but on nissans (im a nissan tech) you only worry when the light stays lit cause then theres a problem. so you shouldnt worry about a blinky light (unless its blinking while driving then theres some serious damage going on)
cool now I can be worred free thanks for looking out
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
